Frigidaire FWS833A Top Load Washer
Problem for Frigidaire FWS833A Top Load Washer
Frigidaire FWS833AS1 - My washing machine recently
By brian_hewitt on Oct 16, 2009
Frigidaire FWS833AS1 - My washing machine recently stopped and wouldn't start spinning during the wash cycle.It will drain, just not spin. Also, it will do the wash and rinse cycles if set manually but then won't spin, If I wait a while I can redo the rinse and spin cycle. There was a smell of burning the first time and some smoke, but no fire.
Best Solution
posted on Oct 16, 2009
Very Helpful)
rylee_smith
Rank: Guru  Frigidaire Expert
Rating: 88%, 1024 votes
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Frigidaire FWS833A Top Load
Questions and Unsolved Problems for Frigidaire FWS833A Top Load
Do you recommend Frigidaire FWS833A Top Load Washer?
Answer
Answer
Smoking from the belt. Put new belt but agitator won't spin. Someone tells me it's the transmission.... (More)
Answer
agitator wont agitate but motor is working frigidaire top loading model fws747rfs0 serial... (More)
Answer
will not stop filling. I set the load limit and it did not help
Answer
we put a pillow in the washer and it made some loud noises probably due to imbalance...now the drum... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
