Question about NetGear RangeMax WPN824 Router
Netgear wpn824 router problem
I have set up the router just the way they say,but the lan port isnt working.i've tried them all and i still get nada...help before i take a five lb sledgehammer to this thing!!!!
  • MurrayM Jan 12, 2008
    I have the same problem. Everything is properly connected. The ip addresses are correct but the modem does not talk to the router.
Sounds like you[ve already found the solution. The sledgehammer combined with going out to buy a new router (anything but Netgear) should do the trick. It's much better than spending countless hours on the phone with a tech from India who doesn't know shit and only asks questions that they are reading from a transcript. Their customer service is shit and so are their products.
Posted on Dec 31, 2007
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
Can I connect non-wireless printer directly to netgear rangemax wpn824?
No you cannot.
To make your printer a network printer you need to connect your printer to a network print server and the connect the print server to the Netgear using a LAN cable.
Feb 14, 2013 | NetGear RangeMax WPN824 Router
My new/replacement modem: Motorola 2210-02, will not work with my old Netgear WPN824. I've tried everything I can think of, and I do not want to buy a new router. Any suggestions??? -Terru
If the modem and the router both want to be on 192.168.1.1, try setting the router to go to 192.168.2.1, or see if your ISP can provide you instructions for turning the router portion of the motorola off (Bridging the modem is the technical term). At that point they may be able to provide you with how to setup the router to work on your connection as the primary connection holder.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 25, 2011 | NetGear RangeMax WPN824 Router
How do i recover my password?
You can restore theNetgear back to the default settings by -
Power up the Netgear, then press and hold the RESET button until the test LEDturns on (approx. 10 secs) then release the RESET button and wait for therouter to reboot.
Connect a LAN cable from the Netgear to the LAN port on your computer, open abrowser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the admin password and configure the wireless settings.
Feb 22, 2011 | NetGear RangeMax WPN824 Router
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
No LAN output from router
This router has 4 LAN ports and 1 WAN port. If you mean to say like if you are running out of LAN ports or if you require more LAN ports to connect more number of computers. Then you can buy a network switch which will help you connect more computers. All you have to do is run a ethernet cable from router's LAN to switch LAN
Aug 09, 2010 | NetGear RangeMax WPN824 Router
How can I set up NETGEAR WPN824 v2
All you need to do is follow the steps below.
1. plug in a computer to one of the LAN ports on the WPN824
2. plug in your modem to the WAN or internet port on the WPN824
3. Turn on your netgear box.
4. Wait for the power light to get steady.
5. Go to your computer. Open internet browser and type http://routerlogin.com .
6. username is admin , password is password. If the default account details didnt work. reset the router for 30 secs and then try again the username and password.
7. go to basic settings. Here you will setup the internet on your router, it depends to your ISP.
If you can go this page, that means your router is still working .
Jun 06, 2010 | NetGear RangeMax WPN824 Router
I have been trying to configure my Netgear WPN824 for so very long, and nothing has worked. I posted on here once before, and I went through a step-by-step list of how to set it up, and it seemed like it...
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 12, 2010 | NetGear RangeMax WPN824 Router
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
NetGear RangeMax WPN824 Router Logo
88 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
