Home | Samsung | Digimax S730 Digital Camera | When i turned on the cam...
Samsung Digimax S730 Digital Camera
Problem for Samsung Digimax S730 Digital Camera
When i turned on the camera, the lens popped out
By frix_djo902 on Oct 16, 2009
when i turned on the camera, the lens popped out then the green light is on but it stopped responding. i remove the battery, turn it on but still it wont respond.i even charged the battery and remove the memory stick
Solution #1
posted on Oct 16, 2009
Not Rated)
BillB-SA
Rank: Guru  Samsung Cameras & Camcorders  Expert
Rating: 85%, 336 votes
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Was this helpful?
Yes
No
Popular Solutions for Samsung Digimax S730 Digital
Questions and Unsolved Problems for Samsung Digimax S730 Digital
Do you recommend Samsung Digimax S730 Digital Camera?
Answer
Answer
I would like to set my S73 camera back to factory settings
Answer
Batterys go dead when not in use-I can take one picture-turn it off--go back in a few hours and the... (More)
Answer
i can not start the camera. I have the "select usb computer/printer messege on the camera... (More)
Answer
The screen is white, even when I pull out the batteries and memory stick for a very long time. Still... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Digimax S730 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
