Question about Toshiba SD-5000
No picture, but sound
SD-5000...Hooked to a Sony Bravia via component cables, now picture, but sound. It was working fine, then had problem reading DVD's. It would stall and function very slowly. Moved TV to wall mount, and now no picture. TV doesn't seem to recognize the SD-5000. Have rechecked all hook-ups several times. seem OK. When hooked up to another TV, same problem, but also no sound. Any clue? Unit is 1.5 months old.
  • Anonymous Jul 27, 2008
    plays sound but not video
  • kettledrum Aug 31, 2008
    My 90 days warranty was just up and now the video no longer works with component or regular red, white and yellow cables hooked to a TV. I do have sound but no video. I was able to get video working by using an HDMI cable, but the TV I want to use with this player doesn't have HDMI.
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Posted on Jan 05, 2008
Thanks - worked for me :)
Posted on Aug 03, 2008
Bravia kdl40v3000 hd chanels have only sound but not picture. What could be the reason?
First if HD via component or HDMI the hookup or more likely the box if used is your issue---some sets will require a firmware update for certain boxes to work--I am guessing but guess you may be using HDMI.
Jun 13, 2012 | Sony BRAVIA KDL-40V3000 Television
Connecting Wii to HDTV - have picture, no sound
You also need to hook up the white and red rcas besides the green red and blue.
Feb 08, 2018 | Nintendo Video Game Consoles & Games
Sony bravia kdl-42v4100 no picture no sound if i disconnect cable running from controller board to main tuner board i get sound but no picture and if i plug it back in you see a picture for a second then...
Sounds like there is a short on the power board or the power board has gone faulty.
Look on the power board to see if any of the capacitors are bulged or if there are any other components burnt out. The TV is going into protect mode because of an over current, which points to a short on the board or a component has gone short circuit.
Thanks
Sep 30, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
Apr 29, 2009 | Sony DAV-FC8 System
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
HD52G887 no sound
Hmm.. If you have your television hooked up via component connection.. you may be forgetting the audio cable. This is a very easy mistake to make while component cables usually dont come with audio or optical audio cables.
Dec 19, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
DVD picture flashes on & off
our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Dec 16, 2007 | Toshiba SD-6000
Toshiba SD-5000 Logo
334 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
