Question about HP Officejet 4215 All-in-One Color Photo Ink Jet Printer
Set on fax and cant get back to print
Paper jammed and when I clear paper, the setting went to fax and there doesnt seem to be a button to push to get back to printer.
  • glo28 Apr 04, 2008
    i cannot get to print, the machine stays on fax. i don't want to fax. i want tro print. i bought new cartriges when i was told i needed them and i still can't get off fax. HELP
    Problem Solver:
  • 18 Answers
On the side of the screen, there will be a button to change the mode. Otherwise reset the pritner and try again.
Posted on Mar 18, 2008
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Is there anyone who can help with this?
just follow the set of procedures HP recommends for clearing a paper jam, and it should work again. They have some documentation and videos online, here is one of them
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&lc=en&cc=us&dlc=en&product=441125
Jul 31, 2012 | HP Office Equipment & Supplies
I have a KX-F880 fax machine... it seems to be in some sort of loop and keeps printing the same page over and over and it says "fax in memory" Is there a way to clear the "fax in memory? I...
Either the memory has gone into a loop or the paper is not exiting the fax correctly and the m/c is going into a paper jam. So that when you clear the jam its prints the same doc again expecting it to be ok. If not then repost and will tell you how to clear the memory.
Jul 01, 2011 | Office Equipment & Supplies
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
"Paper Jam"
Your printer is still trying to print whatever preceded the paper jam. Go to Settings/Printers/your printer/ and clear all documents in the printer que. You will also have to shut down the printer and restart the computer after this to be sure.
qwester
Aug 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
89 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
