Question about Hunter HEPAtech 715 (2 Pack) Air Purifier
Model 717 no longer working...can this be b/c i never changed filter?
I believe I've changed the pre-filter once since I've been using this Air Purifier (probably a year old). Recently, the Air Purifier stopped working (i.e., when I plug in AC power, no response in the LCD display - I remember that i should at least see something when it boots up).
Question: Is my problem because I've never changed my filter??? Are there any additional troubleshooting steps that i should take??
Pleeeeaase help...thanks in advance!
  • 36 Answers
Honestly, whether there's a filter problem or not, the screen should boot up period. If you still have your manual that came with your machine, look up troubleshooting steps provided by the company. (might want to take a look at the warranty for a possible repair under manufacturers warranty). A very familiar hard reset is to unplug the machine, and hold down the power button for a minute (yes, unplugged) then release, plug it in, and try to turn it on. if that doesnt work, I'd attempt to unplug, press all the buttons on the machine once individually, then try again plugging it in, and turning it on. Try all this in a seperate outlet... If it fails, definately call their customer support, cus it may be a defect in the chipset.
Posted on Dec 28, 2007
I want to change filters. please help
Hi and welcome to DixYa, I am Kelly
The only two parts requiring any service are the activated carbon pre-filter and the HEPA filter. No tools are needed. To change either filter, disassemble the unit as shown.
1. Loosen the carrying handle by turning it counterclockwise and lift filter cage cover from unit.
2. Lift HEPA filter and activated carbon pre-filter from the base.
3. Remove the fasteners from the activated carbon pre-filter and remove it from the HEPA filter cartridge.
4. Replace filter(s) as needed, and discard used filters.
5. Wrap the activated carbon pre-filter around the HEPA filter cartridge and secure it with the fasteners provided
Pictures are here:
Thanks for choosing FixYa,
May 25, 2011 | Honeywell Enviracaire 13520 Air Purifier
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
Can I just change the pre-filter because it is full of dust and not replace the main hepa filter
Yes, but keep in mind the warranty requirements:
To receive the full benefit from your Defender ®, replace your filters regularly. • Every 6 months, replace your Enviropure® Charcoal Filter. • Once a year (for Perpetual Warranty*)/up to every 3 years (depending on usage), replace your Medi-Filter® Cartridge.
*Refer to the warranty for information on warranty extension(Perpetual Warranty)
Dec 24, 2010 | Filter Queen Defender Air Purifier
How to change the flter
Turn off the unit and unplug it. Turn the air purifier on it's side and unscrew the locking mechanism (turn counter-clockwise) on the base of the unit. Remove the base assembly from the unit. Remove the filter assembly and find the seam of the pre-filter. Carefully separate the fastener and then remove the pre-filter from the HEPA filter.
Discard the filter(s) being replaced. Then remove the new filter from the packaging and discard the packaging and plastic. Carefully wrap the pre-filter around the HEPA filter so that the ends meet. Fasten the ends together with the fastener.
Place the filter assembly in the air purifier and reattach the base. Then tighten the locking mechanism. Turn the unit right side up, plug it in and turn it on.
You can find a pdf of the manual here: .
I hope this helps.
Oct 03, 2010 | Honeywell 50150 Air Purifier
Kenmore Progressive 335
Hi, filters can be found at amazon, click here and take a look: 1 HEPA Kenmore Air Purifier Filter Fits Kenmore models 83200 83202... I hope this was helpful. Cheers
Jan 18, 2008 | Kenmore 335 CADR Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Air Purifiers Logo
    95 people viewed this question
    Top Hunter Air Purifiers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
