Question about GE XL1800 1100 Watts Microwave Oven
No heat Everything else works light turntable clock keypad.No heating of food at all No heat at all, also makes a crackling noise inside the top of the unit.
  • 579 Answers
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Dec 31, 2007
I have a magic chef over the stove microwave. It sparked underneath when I was using it, it does not turn or heat food nor does the light. But everything else works the keypad,the vent and the clock. It...
Sounds like the high-voltage magnetron (the heating unit) is not getting power. It could be as simple as a broken wire inside the unit (which would explain the spark) or a failed control board or high-voltage power supply (which also might let go with a spark).
Nov 06, 2014 | Microwave Ovens
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Unit is 10 years old. Everything is working (keypad, lights, turntable) but unit is not heating food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 06, 2010 | Maytag MMV5000 Microwave Oven
It appears that the noise is coming from the the turning or spin-
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
You probably have a bad motor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 20, 2008 | GE XL1800 1100 Watts Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Not heating food
While it's possible it could be a door switch or mount, it's most likely a bad magnetron or a bad connection at the magnetron or on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Samsung models here: http://www.samsungparts.com/search/search.asp
Apr 25, 2007 | Samsung MW1030WA Microwave Oven
No heat
The most likely causes are defective a door switch (or switch mount), a bad connection in the high voltage section, or on the controller. I would direct you to my safety text file and door switch text file for critical safety info anf info on testing & replacing door switches. You can find it via searching on Yahoo.com (not Google) for: microwave safety.txt After you check that out, please repost so we can hel you further.
Nov 27, 2006 | Goldstar MV-1501 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
162 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
