Question about Gateway FPD1765 17" Flat Panel LCD Monitor
How to open monitor case
How do you open the monitor case for the FDP1765?
How can I open the case of a Sharp LL 172A-B 17"
Gently pull the frame off because they have lock latches.
Nov 11, 2010 | Sharp LL 172A-B 17" LCD Monitor
I have a viewsonic vx1940w Monitor which will no longer power on. I'd like to take the back off and see if there are any loose connections but there are no visible screws. Does anyone know how to open it?
There is no exact instruction, but first thing you have to do is to remove the stand, then starting at the bottom edge of the case using thin flat blade screw driver to pry open the case up and then work your way around the case, you can also look at YOUTUBE, just search for 'how to repair LCD monitor', 'How to open LCD monitor'
Bad caps (leaking/bulging top) are common failures.
http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | ViewSonic VX1940w LCD Monitor
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
Need to open the case on an ACER 24" LCD Monitor
You are advised to take it in to an authorised technician for repair. Never open the case unless you are qualified and certified.
Jan 02, 2009 | Computers & Internet
Fdp1765 problem
Replace bad caps and reflow bad solder joints.
Aug 30, 2008 | Gateway FPD1765 17" Flat Panel LCD Monitor
How to open the casing of my LCD Monitor Model HP w 1907v
I have a problem of opening the casing of my LCD Monitor, I want to open it so that I can visually check inside.
Jun 19, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Gateway FPD1765 17" Flat Panel LCD Monitor Logo
462 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
