Kenmore stacked washer/dryer - randomly stops in mid cycle
The washer in my kenmore stacked washer/dryer randomly stops working in the middle of a cycle. It first stopped during a wash cycle and never finished. I have since tried moving the dial into the rinse cycle and the spin cycles, and every once in a while it will start up when I pull the knob out, but always stops after running for a few minutes.
Sometimes, when I try to get it started, I can hear the ticker in the timer continue for a few minutes, without the machine working, which then stops. The machine often starts if I set the dial exactly on the rinse button, but never lasts more than a few minutes.
I have taken all of the clothes out but it still does the same thing. I have checked the lid latch and it seems to be fine as well.
I have followed similar threads, but can't seem to make out if this a problem with the timer, the pump, or the lid latch. Would appreciate someone's help.
Complicating matters is that the machine came with a house I bought one year ago and I can't confirm which model it is. The inside of the dryer says Mod # is 110.1820293. I believe it is an kenmore 80 series.
Thanks
  • sabereek Mar 10, 2008
    washer stopped but hear timer
  • 3 Answers
SOURCE: Washer leaks and tub won't empty in the beginning of the cycle
check your hoses all the connections. you'll have to pull the part with the knobs off to do this inside. If it isn't turning, but the motor runs, it might be the coupler in the bottom of the washer connecting the motor and transmission.
Posted on Feb 23, 2009
  • 120 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
  • 523 Answers
SOURCE: i need instructions on replaceing the motor coupler
First you'll need to unplug the unit; after which I'd shut down the water supply and remove these. If against a wall you'll need to move the washer 3-4 feet from it to allow you to tip the washer back. No reason to lay it all the way down just on a heavy angle so you can access the under belly (be certain it will not come back down on you) I expect there is a noise shield you'll have to pull from its tabs. After which you should have a clear view of the motor and see where the remains of your older worn coupling are. I believe on that unit you'll unplug the motor (look for an electrical connection) then there should be two (2) pieces of metal that act like heavy snaps holding the motor in place, using a screw driver or such "un-snap" these pieces (be careful as once there loose the motor is too) this will allow you to drop the motor and gain full access to the coupling. This job should take @ 30 -45 minutes, take your time, keep it clean, keep it safe and in doing so you'll have saved you some good money.
I hope this may have helped,
Tom
Posted on Oct 04, 2009
canbruce75
  • 1776 Answers
Check the video at the following link and see if it is of assitance to you in changing the coupler. Sure hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
lancaster5
  • 245 Answers
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Posted on Aug 23, 2010
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
260 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
