I been having a paper jam, when ever it feeds it tilt to the right. what can i do?
Unfortunately you need to disassembly the hole printer to solve the problem.In most case the object who block the paper is under the white rollers and you can't see it from above.Look for the object from the left side.
Sir,
There can be twofault one is that the Roller of your printer has have got smooth and is not capable of taking in the paper properly another can be that the power to your printer is num. I would suggest you to try get it serviced if the service wont work then you might need to replace the paper roller.
