Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
KDF-60XBR950 I can't swich ON.Green blink once and then red blinks.
  • zenit Dec 28, 2007
    It's starts 10 days ogo.No warranty.My friend has same problem befor and hi just chand (i don't know how you callit)electronic plate H1.
    I allready call tech support ($575)
    Sergeant:
    Champion:
  • 347 Answers
Zenit, When did you start having that problem? havent it turned on once? Do you still have the warranty?
Posted on Dec 28, 2007
  • 1 more comment
  • Santiago Vallejo
    Santiago Vallejo Dec 28, 2007
    It might be possible that You have to call for technic support. Your bulb might be the problem, they can change it, and that will probably fix your problem.
  • Santiago Vallejo
    Yes Zenit, im afriad it is expensive, i heard of some ppl that have replaced that bulb for less. Maybe $300.
    Im sorry so far i havent com up to any solution, ill keep thinking and researching, if i find somthing, i will tell you
  • Santiago Vallejo
    Zenith check this
    http://www.hdtvsolutions.com/pdf/KDF70XB...
    Go to troublechoot, and check video section
KDF-60XBR950 red light blinking 6 times. Please help.
red light usally means bulb is no good, not in properly, or is overheating. if you turn it on and it goes off in short time and starts blinking red then its the bulb for sure. they get hot then kick out and blink..
Aug 18, 2013 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with KDF-70XBR950 TV. The TV won't come on. The power light blinks green for a few seconds than it blinks red for a while until it turns solid red.
How many time it blinks will tell you what the error is. This site will provide you with the service manual and on page eight of it will give you the list of blinks vs problems.
http://www.givemefile.net/smanuals/lcd_tvs/sony/file/8935.html ) ( The middle of the page is the download link "Download SONY service manual KDF-60XBR950 KDF-70XBR950 repair manual" )
May 05, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Mar 28, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a Sony Wega 42'' tv and it blinks green 50x.
If you move or hit or tap tv and you see more blinking that meens has cracked solder .need refresh board solderingin side tv
Apr 28, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Dec 09, 2008 | Sony XL-2100U Projector Lamp for...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
60" Sony KDF-E60A20 - Red Light Blinks 6 times
The problem you have is a failed thermal sensor. Depending on how tech savvy you are you can replace it.They have changed the way the thermal sensor looks but it isnt too bad too put in. Any repair shop should also be able to do this for you.
Part number is 1-910-006-44 Themal Fuse Sony Part.
Feb 04, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
