Question about Denon AVR-2106 Receiver
AVR 810 Denon Receiver Sub Woofer Hookup?
My father has a AVR 810 Receiver and Polk Monitor Series Sub Woofer and I need to know the proper or best way to connect the Sub to the Receiver. I have not found the connections info on the web for the Receiver on the manufacturer site.
Can you help?
  • denny9526 Sep 28, 2008
    I also have a Denon AVR-810 and while changing out the gold pins on the Monster cables I hooked up the unit went into PROTECTION mode despite having no speakers hooked up to the inputs it still shows the Protection mode on the display?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Posted on Jan 04, 2008
Pre out for Sub woofer on AVR 1601 not working
Is this a new problem, as in it worked before? If it's a new hookup, it's possible the sub you have isn't powered. In which case, it won't work. PRE out is 'preamp' for powered subs.
Dec 27, 2013 | Denon AVR-1601 Receiver
Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Dec 11, 2007 | Denon AVR-4800 Receiver
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Jan 05, 2011 | Audio Players & Recorders
Cant get klipsch sub woofer to work. do is there a menu setting through receiver to do this?
What model is the sub? Is your Klipsch sub powered? If it's already plugged in and powered on make sure you have the RCA cable going to the correct LFE output on the Denon and have it set to 5.1.
Jan 03, 2011 | Denon AVR-1601 Receiver
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
No signal coming from sub woofer out
set the front speaker to small or if still set in large,set the subwoofer setting to lfe+main.
Feb 18, 2010 | Denon AVR-1708 Receiver
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Apr 10, 2009 | Onkyo TX-SR875 Receiver
Is denon 1356 with active bass. and i want to know the difference between active bass and passive bass.
Hi....
A passive bass is a box with a sub-woofer in it.
An active bass is a box like that with an amplifier built in.
Hope that helps.
Check the Denon site too
Dec 26, 2008 | Denon AVR-1803 Receiver
Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems?  Sqeaky hinges get the oil.
Nov 12, 2008 | Denon AVR 2808Ci Receiver
Denon AVR-2106 Receiver Logo
918 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
