Question about Dell Dimension 2350 PC Desktop
Internet connection my dell dimension 2350 will not recognize ny internet service. I went to tools, connections , set up internet conection. No luck, also went lan settings entered IP address, No Luck ! went to connection wizard clicked finish and still No Luck!!
When you start the computer up hit F1 for setup of the motherboard and make sure that you NETWORK device is enabled.. nic.. "UNDER DEVICES"... and if it is disabled you very well have to turn usb 2.0 sup and root hub sup. and usb mouse .. enable all of that.. good luck..
Posted on Jan 18, 2008
I had to deal with the same thing when i got internet at my house using the same computer as you,if you are using a router,it could be the router that has problems.if you arent using the router,then i would call the internet company and have them come look at could be a broken connection in the DSL line and it may not be reaching your home,causeing your computer to not be able to establish a connection to your internet
Posted on Jan 13, 2008
  • 625 Answers
Start your machine and go to hyper terminal.START, ALL PROGRAMS, ACCESSORIES, COMMUNICATIONS in here type your server's phone number. if your modem is working it will try to connect with hyper terminal and if a connection is made, will ask you for your password. this will verify that the modem is ok. if this works, then re-install your modem's drivers and reconfigure new internet connection.
Posted on Dec 28, 2007
How do i connect to the internet on dell dimension 2350
How did you write this msg as this is on the internet
Apr 05, 2014 | Dell Dimension 2350 PC Desktop
I download the ethernet controller for the dimension 2350 but everything I try to download says that I am missing my internet connection. I have an internet connection, I just can't download certain...
If you are on the internet via your ethernet card why do you need ethernet drivers?
is there any pattern of where you can and can't go on internet?
could be malware, download malwarebytes antimalware free
could be dns problems
Aug 29, 2010 | Dell Dimension 2350 PC Desktop
I reinstalled windows xp on my dell dimension and now i am missing all drivers and cant connect to the internet
You will have to go to the Dell site and at least get the network driver and put on a jump drive but it will have to be an old jump drive because the 2350 may not recognize some of the newer jump drives that have security features (I know that is a pain!) What I do is download the whole lot and burn them on a CD. JC
Nov 17, 2009 | Dell Dimension 2350 PC Desktop
Router dell 2350 not detect by computer
open a explorer session go to tools/ internet options/connections/lan settings check off Automatically detect settings click ok, ok close explorer then open a new session and see if you get internet.
Oct 17, 2009 | Dell Wireless 2350 Router
Internet connectivity issues with Dell 2350
then open control panel
add new hardware click yes or next scroll down to network hit next or yes
then first try with automatically detect
then restart pc when it's done
do you know your exact ethernet driver
do you have a internet icon in your taskbar
Jan 15, 2009 | Dell Dimension 2350 PC Desktop
Ethernet Driver
Yes, you need to download Enthernet driver for you system and you can easily find on Dell's website.
you can even search driver using serivice tag which you can find on your computer.
thank you
and do not forget to vote all answers.
Jan 11, 2009 | Dell Dimension 2350 PC Desktop
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
Dell Wireless 2350 BroadBand Router
You may get some benefit from downloading and installing Netstumbler
This util will allow you to scan the channels and select a chanel with less devices on it. then change the broadcast channel in the wifi router. This may reduce interference in the connection.
Also cordless phones are notorious for interfering with wifi routers so put some distance between the router and the base if you can.
Another option is to get an external antenna for the router to boost signal strength
something like THIS or THIS and place up high on a shelf. Just check your router antenna is the sort that comes off... should unscrew. not all do unfortunately so be careful not to break yours!!
BTW - the router is not a bad unit but it also is not the best around either REVIEW
Jul 19, 2008 | Belkin 802.11b Wireless Notebook Network...
Dell dimension 2350
if you use a flash light and a magnifying glass all the conection pins will be labeled ;like AUX in, for auxillary in which is usually for usb ports and plug and play items, then there will be a power reset set of pins for the reset button, and LED pins, and then your power should be labeled like wise. some times it wont be but you can look at the connector see if it has 3 or 4 wires and find the plug in that matches that has a u shaped metal place by it. its usually the power connection but if you are not sure take it to a professional so you dont cause damage.
Dec 08, 2007 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
138 people viewed this question
Alun Cox
