If it is spinning then you may have lost a 110 leg on your electrical outlet that causes the heaters to come on. Start there and work your way back to the dryer. You should have 110 from the ground(lower center hole) to the hot left hole. You should also have the same on the 110 ground to the right hot leg. if you check both the left and right together you should have 220/240 volts. If you don't stop right there and call an electrician. If you do have 110 on each leg as we call it giving you a combined 220/240 volts (it sometimes varies) move up the line to dryer. Either the heater coil has broken (good time to check for good airflow at the vent) or a non resettable thermostat has been tripped causing the heaters to stay off. Poor airflow can cause these two things to fail. The thermostat will need to be replaced if it is the non resettable type. The heaters may have gone too. Those should be checked as well.
