Question about Bose 3 2 1 GSX System
VOLUME ISSUE I CONNECTED MY BOSE SYSTEM TO MY TV BUT I ALMOST HAVE TO TURN THE VOLUME UP TO 90 TO HEAR IT COME THRU THE SPEAKERS. I HAVE A DIGITAL CABLE BOX AND WAS WONDERING IF THAT MIGHT BE THE PROBLUM. WHEN I HAVE IT ON THE FM SETTING THE SPEAKERS ARE NICE AND LOAD AT THE LOWER VOLUME LEVELS. ANY HELP WOULD BE GREAT. ADAM
  • BrendaLea Jan 23, 2008
    i have the same problem with bose 321 fm works dvd works and cable used to work all of a sudden one day had to turn up cable to 100 to hear it at what would be 40 normally? Any solutions?
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Posted on Jan 16, 2008
After working fine for a few years, I had problems with the functioning of my Bose. They sent me a CD to update the firmware and it fixed the problems I was having.
Posted on Jan 09, 2008
I talked to Bose Support on this issue. I have the same problem basically on my 321. Bose support rep. told me that that this is pretty typical for the Bose system. The Bose is a gradual volume system and the max volume goes as high as 110 where as other volume systems do not.
Posted on Jan 07, 2008
Bose cinematic autoshut off
The device which sends Audio to Bose causing this issue. I have my Bose Cinemate connected to TV and it will remain until I switch off Bose Interface via remote (Even TV is switched off).
Overheating cause this issue, so keep the Cinemate to have some space to cool.
May 24, 2014 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
Good morning. I want to get an idea on how to connect my Panasonic lcd TCL32X1X to my Bose Sound System. What I want is to hear tv programs thru the Bose speakers.
TV's are video OUTPUT devices, not sound INPUT devices.
Get the TV-related audio into the Bose directly from the digital audio output of the same source from which the TV is getting the video. You can also run a mid-fi RCA analog stereo feed to the TV (if it has speakers) so you can watch and listen to stuff without the Bose turned on.
Jun 28, 2010 | Audio Players & Recorders
Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Feb 03, 2010 | Bose Cinemate Digital Home Theater System...
Volume issue
The red/ white RCA is the most correct way for you.
Just to confirm it's analogue tv not digital you are watching?
Your friend is correct for when you watch from a settop box or pay tv provider you can run an optical cable to the bose -but- most tv's don't have an optical out.
SO- can I confirm that you can get sound out of just your tv on it's own?
I'd say that the audio outs on the back of your tv are "linked" to the tv's volume control, so you have to turn up the volume to get a louder output. Some tv's are advanced that you can disable the tv speakers, and permanentlyh set the tv output to a fixed level so you can use your surround sound (and Its volume control)
Try this one if you can.
Jan 17, 2010 | Bose 3·2·1 II System
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
LG 47 External Audio Control
This is the only way a bose works
May 01, 2009 | LG 47 in. Flat-Panel LCD HDTV
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
Bose 3 2 1 GSX System Logo
947 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
