Question about Teac CD-X9 Shelf System
TEAC - CD-X9 - No sound in left speaker
I've only this a couple of times in 18 months, and when recently hooking itup, there is no sound on the left speakr (the speakers both work .. I switched the left and right jacks), but nothing works out of the left jack on the back of the sub-woofer . I get bass and sound on the right output only. Any thoughts?
  • 1 more comment
  • RickGraves Dec 28, 2007
    Thanks, I checked both ends of the cable between the sub-woofer and the main unit, and one of the pins was bent to the side (and not inserted properly when I plugged it in). I straightened the pin, plugged both ends up, and voila ............. working great .. THANKS
  • Cocamo May 18, 2008
    Seems that there is a consistant problem with this TEAC as pertains to the difficulty of connection. I had exactly the same experience except my 3.5 amp fuse bit the dust when I plugged it in. The connection is very "rough" and the pins bend much too easily. Now I am struggling trying to find a 3.5amp 120V fuse. I've searched electronics outlets and even visited several NAPA stores, but I find only 2 amp or 5 amp fuses. Any suggestions where I might be able to secure this odd fuse? I noticed that the other fuse in the panel is 4amp 120V. Whoever designed the circuit board should go back to engineering school.
  • Anonymous Mar 28, 2014
    speaker hook up
    Problem Solver:
  • 7 Answers
The speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Posted on Dec 28, 2007
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
Just bought the speakers of a teac cd-x9 thinking it was for a pc. Is it even compatable? If so, do you have a pin out for the input plug? thx
Pin-out??? It's a standard RCA AUX input that accepts and standard stereo Line Level source. Your PC has that or a 3.5mm output that can be adapted to standard RCA.
http://www.pacificgeek.com/product.asp?id=39101
Aug 11, 2011 | Teac CD-X9 Shelf System
Does the Teac Micro Hi-Fi System CD-X9 support an Ipod nano?
  • Not in the format that IPod supports but it easy enough to convert the IPod songs to the MP3 format that would allow you to burn an MP3 disk that will play on that system.
  • You want to convert it to MPEG-1, Audio Layer 3, 44.1 or 48 kHz fixed bit rate.
  • Here is one of many site you can download the converter from http://www.winmpg.com/ipodto/ipod_mpeg1.html
  • Once you convert the ITune then just burn it to a CD-R or CD-RW disk and the system will play your songs just fine.
  • Hope this helps.
Regards, Tony
Jun 07, 2011 | Car Audio & Video
How to hook it up to a amplifier
sound source out(dvd-cd player)-------------to teac eqa-5 in-----------------teac out---------to amp line in.
Oct 31, 2009 | Teac EQA-120 Home Equalizer
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
JBL on rour stop working one hour later every time
Hi, I got my on tour a couple of months ago and it worked fine. But just recently it starts stopping emitting any sound one hour or so after I start it. No sound at all, and the light goes off too. If I press one of the buttons, the light will glim just once.
Aug 01, 2008 | JBL (JBLONTOUR) Computer Speakers
Teac AG- D8900
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
Nov 27, 2007 | Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Jan 14, 2007 | Teac AG-D8900 Receiver
Teac CD-X9 Shelf System Logo
493 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
