Panasonic SC-AK18 CD Shelf System
Problem for Panasonic SC-AK18 CD Shelf System
Has power but no sound
By joedogjs on Dec 27, 2007
i had the stere on volume 7 and the sound just went out and i cant get no sound at all but the reciever itself turns on and works fine what would cause this problem is it a fuse?
Same Problem
Feb 01, 2008
-   Has power, all functions seem to work, appears to play CDs..but no audio out of either speaker at anytime..not even a buzz or anything...no visible fuses on circuit board, etc..any ideas? Anyone know if there is a schematic for this available (GE 75300)-   MarkB-CO
Jan 31, 2008
-   Yes, same problem. No sound from speakers but otherwise everything working OK. No it's not a fuse or final amp problem. The final power amp on the bottom board is fine, there's no sound coming to it from the middle control board on either channel-   Dacity
Jan 31, 2008
-   Yes, same problem. All functions OK but no sound. Main power amp board at the bottom is fine.... there's no audio coming to it from the centre control board,-   Dacity
Jan 25, 2008
-   it has power but no sound at all and no sound level in the display and the fan doesn't work....-   Guest
Jan 17, 2008
-   my sony system shows it has power, by a little red light on the front . but no lcd lights cd rack won't move , radio won't turn on like if it had no power at all.-   aodawg72
Best Solution
posted on Dec 28, 2007
Very Helpful)
ReldvS
Rank: Guide
Rating: 92%, 4 votes
it could be a fuse, i would check that for sure. i would also look at the stereo speakers for fuses there. i have seen some that fuse at the speakers. I would unplug from the wall and allow to cool down. Thermal fuse will reset itself. see if any of that helps.
Was this helpful?
Yes
No
Solution #2
posted on Feb 18, 2008
Somewhat Helpful)
Trippynet
Rank: Wiz
Rating: 83%, 36 votes
F-16 Is an amplifier ic problem you would most likely have to replace the main power amp plus its power regulator.
Was this helpful?
Yes
No
Solution #3
posted on Jan 09, 2008
Not Rated)
parran H
Rank: Apprentice
Rating: 0%, 0 votes
Have problem with mij radio.
the display show's me F-16
wat could be the problem
Was this helpful?
Yes
No
Popular Solutions for Panasonic SC-AK18 CD Shelf
Questions and Unsolved Problems for Panasonic SC-AK18 CD Shelf
Do you recommend Panasonic SC-AK18 CD Shelf System?
Answer
Answer
panasonic cassette 5cd powre on error f61 problem
Answer
Had power surge last night and unit would not turn off. Switched it off manually & this morning... (More)
Answer
I have panasonic SC-AK18 shelf system. It displays F61 error. As per your solution i changed the... (More)
Answer
when i switch on,in the display appears "F61" and it switch off.!!!HELP!!! Please offer... (More)
6 Other Users Have The Same Problem - Continued
Comment by efg11, posted on Dec 29, 2007
I too have power, and sound in one speaker only - have checked all connections to speaker and also checked they are same as working speaker. What else can I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
