posted by conway192 on Dec 27, 2007
why cant i access the web based managment modual it just says web page unavailible error 400'
Best Solution
posted on Jan 03, 2008
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Lan Settings:
click ok.
Good Luck.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for D-Link DSL 300G+ Modem
Email this problem
Email this problem
Can you Help with these Modems problems?
Repair Service
Find Modem Repairman Near You:
