Question about Dryers
Crosley dryer-model # cde6500w
I have a crosley dryer model number cde6500w. I replaced the thermal fuse. The dryer worked for three cycles. The thermal fuse came in a high limit thermal kit, that consisted of two fuses and the high limit thermostat.The fuse that i replaced had a red dot on it. The other fuse has a yellow dot. When the dryer stopped i heard click sound. Where is the fuse with the yellow dot located? Can the fuse with the red dot be purchased separate?
  • hrvenus Jan 05, 2008
    I have a Maytag and the thermal fuse blew. The old thermal fuse had a red dot on it. I purchased a new thermal fuse kit for the correct model however it came with two fuses, one with a pink dot and one with a yellow dot. The pink dot one is the one I used but it blew immediately. The yellow dot one (which says it's for gas but my dryer is an electric) works. Is this just because it's actually bypassing the fuse or what? I don't understand why the thermal fuses I got didn't contain one with a red dot (which I thought was for high temp)? Any help would be greatly appreciated!
I believe that you probably purchased a kit of fuses which provides fuses for several different types of dryers. That way the parts store can sell you the kit without knowing exactly what type of dryer you have. If I am right about this, there is no yellow fuse in your dryer, you will need to buy a new one to replace the red dot fuse. Also, you will want to find out what is causing it to blow again so quickly, probably your exhaust duct is a little plugged, causing the inside chamber to get too hot.
Posted on Nov 24, 2012
5 Suggested Answers
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
SOURCE: crosley CDE6500W
This will show you the parts diagram. You can do it from there.
http://www.partselect.com/MultiModels.aspx?ModelNum=CDE6000&searchTerm=&RefineSearch=0
Posted on Feb 01, 2008
manhandy
  • 146 Answers
SOURCE: crosley cde6500w dryer has power will not work.
check the cord, check the safety switch on door. any internal fuse? last check section switch
Posted on Jun 24, 2009
  • 18 Answers
SOURCE: where is the thermal fuse for a crosley cde6500w
The thermal fuse for this dryer is located on the right side of the heating element behind and near the top/left of the drum. You will see two white wires leading to it. The Thermostat is right above the heating element - two red wires lead to it.
Posted on May 27, 2010
Dryer not heating
Yes, you probably need a new heating element as you did not list this as being replaced or checked.
Nov 10, 2015 | Crosley Dryers
Crosley CDE8000gbl can not find thermal fuse part number
-Check With reliable part . They should be able to give you part number.
Good luck
Mai
Dec 14, 2013 | Crosley CDE6000 Electric Dryer
My Crosley CDE6500W has no power, not even the light inside the drum. I checked the power from the outlet and it is good. Were are the fuses or could it be something else?
The fuse is located here:
The main thing that cause these thermal fuses to melt is a loose blower wheel and air restrictions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 08, 2011 | Crosley CDE6000 Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Where is the thermal fuse for a crosley cde6500w
Apr 14, 2010 | Crosley Dryers
Model #CDE6500W Crosley electric dryer has no inside light and will not start; the breakers in the house are ok it is like the power was shut off.
The fuse mounts beside the heater and the usuall cause for it to blow is a loose blower wheel or a ball of lint in the filter housing. Check out these repair pictures
Jul 24, 2009 | Dryers
Crosley cde6500w dryer has power will not work.
Jun 24, 2009 | Crosley CDE6000 Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
CDE6500W Not Heating
The part number is 53-1641. It comes with a high limit and is around $50. You must pop the top on this unit and you will finnd the element in the rear of the dryer. A simple and easy fix.15081c8.jpg
May 19, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
574 people viewed this question
Top Dryers Experts
Marvin
Marvin
