Rank: Guru
Rating: 89%, 14 votes
F5 is exposure lamp problem, to fix this problem try these
solutions:
Solution1: switch off and on the machine.
But if this is not working try solution 2
Solution 2:
Step1: Press continuously
Clear
key then I
nterrupt key then
Zero key then
Interrupt key
Step 2: You are inside the simulation if the display turns off but if not
do again step1.
Step 3:
Press 14 then press print button
Step 4:
If not canceled try step 1 to step 2 again then press 16 then press print button
But if this is not working try solution 3
Solution 3: try to open the platen glass and clean the
mirrors and also the bottom side of the platen glass especially the white
correction plate then apply solution 2.
Comments:
Oct 16, 2009
- If you have anymore error codes refer to this site for a basic description.
http://www.visualhawk.vcc.ro/sharp_error_codes_en.html
