Their is air in the system pull the washer pipe off press the jet for the water to come through this should be enough.
Failing that pull the pipe off at the pump the the water run through the pump put the pipe back on and the water should pass though no problem now
Possible blockage in line or at the nozzle ends. There is a small screen that keeps debris from entering the lines but can get clogged. The screen is plastic and is inside the reservoir at the bottom between the pump and the outlet hose. Remove and clean the screen as needed. If the problem persists there is most likely a clog in the line. Slightly higher pressurized air (more than the washer pump can produce) could clear the clog. Be sure to check the nozzles for blockage too. Good luck to you
Check the hoses and the nozzles. One of them is clogged if pump is working. Pull hose off pump first and see if fluid comes out when washer is activated. If you get no fluid and the pump is running replace the pump.
