Question about NexxTech DP3222 DVD Player
  • NEXXEN Jan 03, 2008
    Need to adjust the output to YpBpPr via settings
Go to setup menu;under video out-set to yuv--problem solved!
Posted on Feb 27, 2008
The ypbpr input is showing up all green
Try changing the input device to some other. Look for any loose contacts in RC jacks/sockets/Cable. Check and ensure that the color system selected like PAL/Secam etc. is matching. Try changing the detection of color system to auto mode.
Aug 04, 2012 | ViewSonic N2750w 27 in. HD-Ready LCD...
The plug got torn off the the back and i do not no what or were to hook up the break lights nor do i no how to add a plug for a trailer can you please help me out
  • Hi, not sure which one you have so I will list both for you.
  1. Ground - Black
  2. Blk/Orange - Park lamp relay output
  3. Yellow/Pink - Trailer tow right relay output.
  4. White/Pink Trailer tow right turn relay output.
  1. Nothing.
  2. White/Pink - Trailer tow right turn relay output.
  3. Violet/ Black - Back up lamp feed.
  4. White/Red - Fused (B+)
  5. Black/Orange - Park lamp relay output.
  6. Nothing.
  7. Black - Trailer tow brake (B+)
  8. Black - Ground.
  9. Black - Ground.
  10. Yellow/Pink Trailer tow left turn relay output.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 12, 2011 | 1999 Dodge Ram
Pages come out pink only when printing in colore
The magenta developer is bad.
The developer drive on this printer rotates in both a clockwise and a counter clockwise direction to turn the developers.
When printing black, ( i cant remember which direction it turns, ) only the black developer turns.
When printing color, the developer drive turns the opposite direction, engaging ALL 4 developers.
( the developers are the multi colored bars you see when you remove the image drum unit.)
This is why you do not get the pink output when printing only black.
your choices are to set the printer to only print black and white. ( you can do this in the printer properties for your print driver). or you will need to replace the magenta developer.
Feb 07, 2011 | Dell 5100cn Laser Printer
What is the problem if my LG w1934s-BN LCD monitor when the color of the screen is pink ?
The reason for that is because the main board inside of the monitor is bad and since there are no parts for that monitor available you would need to replace the monitor. The main board controls the output of colors onto the lcd.
Sep 30, 2010 | LG W1934S-BN 19" Monitor
This is imbalance of the white balance of the camera. If there is no fault with outdoor shots then the CCD does not compensate the high intensity flash specially when bounced closer.
Set the camera manually to outdoor high brightness and test.
If the pink seems to come back irrespecitve of any of the settings the CCD circuitry is faulty.
Sep 17, 2010 | Samsung Digimax S700 Digital Camera
The color on my tv is mostly pink. Is this
Try a reset to factory defaults. Show some image with lots of white. If it is still pink, it could be the backlights starting to fail. Or a circuit board. To be sure, you would have to disconnect the LCD panel from the board and turn on the set so that you have a blank white screen....with no signal. A pink screen, backlights are bad.
Apr 23, 2010 | Insignia IS-LCDTV32 32 in. Television
Picture went to all pink but menu is in full color if bypass hd inputs picture is fine and using rca cables picture is fine its just the component connections that turn screen all pink
Your output device is likely trying to send out a YPbPr signal. On the output device try switching it to an automatic mode ideally or manually switching it to RGB. On the PS3 it is under the Video Settings section (Not the display settings.)
Jul 20, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Did you make an aligment and a calibration of your cartridge???
Mar 29, 2008 | HP DeskJet 810c InkJet Printer
TV lacks green, but has prominant red/pink
Getting the squematic will be the first step to take to become more familiar with the electronics inside,you can ordered by going to click on service manuals and give them the model number,they will then give a price and availabilty.The color processing uses a driver for each color and an output for each color too,the output are ussually placed in the crt board in theneck of the tube.the drivers and outputs are transistors most of the time but sometime the drivers are part of an integrated circuit.Please let US know if you need more help but place it as a new question.
Oct 11, 2006 | Mitsubishi CS-35707 35" TV
Everything is pink
This looks like first stage of CCD sensor failure ( it is starting to output 'noisy' signal )gets worse so that the sensor eventually outputs nothing and you will get blank shots. Ask Pentax if this model with CCD problems is repaired free of charge since most manufacturers do it for nothing or only charge for labour to have a new sensor installed.
Oct 01, 2006 | Pentax Optio 60 Digital Camera
NexxTech DP3222 DVD Player Logo
114 people viewed this question
Top NexxTech Televison & Video Experts
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
