Heaters
Problem for Heaters
Generic problem for all Heaters
Floor furnace
By judibleyz on Dec 27, 2007
i got it lit, but i can't get it to kick on....it is a ward heater company 40sdr....also, what is the stick adjustment thingy next to the one marked pilot......i can read the one marked "pilot" but the other one is illegible....it has markings for on and off
thanks, judy
Same Problem
Dec 11, 2008
-   The floor furnace is an American Standard and this right hand on/off is for the burner. This rod that extends down into the unit will not turn on and I was wondering if it is just stuck and needs to be freed or is it broken where it won't turn on or off. The burner was on last heating season and was fine when it was turned off. Now it will not turn back on. I don't want to force it where I may break the rod, but it is getting cold now. Would it do any good to put some WD on the valve? Any help I can get would be appreciated.
-   Guest
Solution #1
posted on Dec 28, 2007
Somewhat Helpful)
hotuna
Rank: Guru
Rating: 86%, 319 votes
That is the control for the main gas valve. These old ones have a gas valve separate from the pilot. Also the regulator is separate unit. You have to turn these controls with a long rod, right?
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
What is the best portable heater for a 700 sq ft area
Answer
how can you buy things for less than what they ask for?
Answer
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles.... (More)
Answer
I have a solid fuel and wood burning open fireplace which was fine last winter. This year I am... (More)
Answer
The company I work for is moving into a building with some Dayton model# 3E847 heaters in it. Where... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
