Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator frigde is leaking from freezer- water freezes on the floor of freezer then leaks water out under the door onto the floor
  • 1 more comment
  • sjslay Jan 09, 2008
    Same exact issue...Please help!
  • CathiB Mar 10, 2008
    I have a Maytag Model MSD2650HES Side-By-Side Refrigerator which is less than two years old. It has started leaking water all down the back of the freezer from where the line comes into the back of the freezer at the top. It freezes and there is ice all the way down the back and at the bottom inside. I turned off the water to the icemaker and it finally stopped after the line cleared out. How do I fix this leak?
    Thank you,
  • zzyzz Jul 24, 2008
    I have a Kenmore refrigerator that is 10 years old.  It leaks from time to time in the freezer area on to the floor .   We noticed recenlty we put our hand to the back of the freezer and we felt hot air.
    So far we have raised the temperture in the refrigerator and also made sure we do not keep the door opened.
    Anyone had this problem?  Thanks.
    Marie J.
My kenmore frig side by side did the same I flushed the freezer drain like the instruction book says but it leaked on the floor after A week.
I pulled out the frig unplugged it in the back I removed the bottom black cardboard grille and vacuumed the underneath and removed the black drain tube and flushed water through it and put it back that solved the problem and took about 15 minutes to do I hope this helps people who are having repeat trouble.
Posted on Jul 20, 2008
It did work but after a while it happened again. I keep the freezer temp to med. It did start after installing the ice maker. So now the water is shut off to the ice maker. I removed the bottom panel in the freezer held by 2 screws and removed the sheet of ice gently. Will castor oil in the drain hose help? Thanks for your help!
Posted on May 17, 2008
  • 288 Answers
This is the most common thing on this site for refers. Its the drain line that takes water from the freezer when it defrosts to the pan underneath the appliance. You need to locate the drain line and remove the obstruction, sometimes its frozen so a short thaw may be helpful. The way I do it is I find the drain hose at the bottom of the fridge where it drains into the pan. I then connect a hose to it and blow compressed Co2 into the line. When there is no back pressure, I know its clear.
Posted on Jan 13, 2008
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
My frigde is leaking water and it creates a block of ice under the freezer drawers. Can this be fix and How??
have you installed a new water filter lately? If so, check that it is securely installed, as water could be leaking by it and forming in the bottom.
Nov 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaks into bottom of freezer. it re freezes, and then also
hi there,
there a leak somewhere in there. there is no way you can fix this yourself, call the repairman or LG's customer service.
Jun 07, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
222 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
