Question about Fuji FinePix S5000 Digital Camera
Switch glitch When i turn on my camera it goes off again within a few seconds (or maybe less). I have to turn it all the way off (slowly) and on again. Sometimes it stays on (at least long enough for a photo) and other times not. Has been getting worse so now the camera is pretty useless. I am presuming that the switch has had it (any other suggestions?) Interestingly while it was under warranty i had switch problems and it was replaced so this is the second switch on the camera. Is the switch a common problem with this carmera? Is it worth fixing? i had really like the camera up until recently.
  • 667 Answers
I have the same camera and it does something very similar. I'm guessing it is not the switch but rather the internal battery for memory backup needs replaced. It is not a do it yourself repair nor is it cheap. One option you can try is to use the setup option in the camera shooting mode and adjust the power saver feature. It has 3 settings, Off, 2mins, and 5 mins. Set it to off and see what happens
Posted on Dec 29, 2007
My chrysler voyager mini van all of the sudden began overheating...it goes up to the red and starts beeping within a minute. The fans are working fine and water is flowing through radiator fine. It did...
I think you have a leaking headgasket or a coolant leak. Have the cooling system pressure tested first, if no external leaks show up then you have a possible leaking headgasket.
Mar 21, 2017 | Chrysler Voyager Cars & Trucks
Canon 580 EXII turns off slowly
If you restart it immediately, and the unit seems like it is just starting, it may be the charge capacitor is shorting out, or there is excessive gate leakage of the thyristor
Feb 18, 2012 | Cameras
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
It turn the power on and on again and nothing happens
This is a common problem for all Sony Cybershot digital cameras. It is saying the error "Access" because whenever you turn it on, the camera finds it hard to retract and open out the lens. Chances are, there is some sand or maybe dust or dirt of These are few things you can do.
You can blow a compressed air on the camera's lens to try to take off the dirt or granule of sand stuck within the lens. Also, you can try to hold the camera from your right hand with the lens facing the ground and hit the camera's base on your left palm. Do this several times.
Let me know if this helped you. Goodluck!
Sep 16, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lenovo T61 integegrated Camera not working
Check the settings for the autobalancing, something sounds like it's glitched. Also, try the head-tracking. Try turning it off and returning it to normal zoom.
Dec 28, 2008 | Lenovo ThinkPad T61 Notebook
Kodak V1003
Hello!!!
please remove your batteries and press the power button for few seconds and replace the batteries now and try switching on ...
Regards
Smilemaker.
Jul 19, 2008 | Kodak EasyShare V1003 Digital Camera
When I try to record in Memory Card mode the camera fails
reset it. if it still doesnt work.
try reformatting the card.
Dec 24, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Monitor goes black
It always does that while it's powering up the flash again. If you're saying it doesn't come back after a few more seconds, that is a problem. Or maybe by that time, the power saver kicks in. You can tell if the power light starts blinking. Then you just have to press the shutter button again to turn it back on.
Aug 20, 2007 | Nikon COOLPIX L5 Digital Camera
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Fuji FinePix S5000 Digital Camera Logo
57 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
