Question about BenQ PB6100 Multimedia Projector
Everything is red.
I recently powered up my BenQ 6100, to find that the picture is fine, with normal clarity, except the picture has a very reddish tint to it. Enough where it looks as if I've put red Saran Wrap over the lens. I've looked in the settings for color correction, but I am unable to find anything that helps at all. Any help would be greatly appreciated.
-Matt
  • Anonymous Feb 13, 2008
    yep...red saran wrap over the lens
  • Disney66 Mar 21, 2008
    I have the same problem with my 6100 except everything is tinted blue. It first started only when my dvd player was in progressive scan mode but now does it all the time. Hooked up another DVD player with the same problem...so it's not the DVD player. Any help would be appreciated.
  • 563 Answers
Hi guys
The colour change can only be one of two things :
1. Faulty Cable
2. Faulty Mainboard
Must warn you that a Mainboard is quite expensive to have replaced.
Posted on Apr 01, 2008
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Hdmi on my sony PS3 not working
Have you changed your HDMI settings recently? Make sure you are using the correct resolution supported by your HDTV. The audio settings can be changed independently to the display.
You can reset the display settings by turning off the PS3 and holding down the power button down for 10 seconds.
Jul 14, 2009 | Sony PlayStation® 3 (60 GB) Console
No Picture
Ok. It still might be the bulb, if not make sure it is plugged in to a working outlet. Also, if that doesn't work unplug, wait 1 hour, push the power button (with it unplugged) then plug it back in. If nothing fixes your problem, it is the power supply.
May 24, 2009 | BenQ PB6100 Multimedia Projector
BenQ PB 6100 .. blue hue on everything !
Most likely (90% sure) you need a new Main Board.
This Board is for sale on Ebay... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170296659472
Nov 08, 2008 | BenQ PB6100 Multimedia Projector
Reddish tinged photos
It might be a possible CCD defect , as usually the symptoms are odd colours in a photo hence your red tinge in your photos.Its quite expensive as it labour intensive to fix .Rather just buy another camera or you can try to solder another ccd from anotehr camera > look on ebay for parts (not recommended precise alignment needed).
Sep 25, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
BENQ FLAHING
Hi cvijr
This can only one of two things - the lamp or the Ballast ( lamp's powersupply )
Normally the PB6100/6200 lamp's has got markings on the lamp itself when this flickering occurs.
Take out the lamp by unscrewing the lamp door at the bottom. Then look for any vein like looking marks in either black or white. Or even a bubble at the bottom end of the lamp's shaft.
If you can spot anything out of order , then the lamp will need replacement.
If not , then you'll know for sure that it is the Ballast that is in need of either repair or replacement.
Part Numbers :
Ballast :5D.J8612.011
Lamp : 60.J8618.CG1
Hope this is of help and thanks for using Fixya !
May 05, 2008 | BenQ PB6100 Multimedia Projector
Benq pb 6100 projection from left rear of room
Hi there
This is unfortunatelly not possible at all on the PB Series Projectors. I'm a ASP Technician for BenQ Projectors and know then like the palm of my hand.
Mar 30, 2008 | BenQ PB6100 Multimedia Projector
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
Red Screen
you camera is experiencing CCD image sensor failure, very common problem with Canon cameras, Canon offer free repair, follow this link: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=10462&keycode=2112&id=29819
Aug 19, 2007 | Canon PowerShot A85 Digital Camera
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
BenQ PB6100 Multimedia Projector Logo
172 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
