Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
LE=Load Error CE=Cycle Error Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire. Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load. If it happens again, unplug for two hours to reset the Error Sensors. Hope this helps.
sensor error
The connector (5-pin, male, white) in the wire harness is not connected to the connector (5-pin, female) of hall sensor in
the MOTOR.
' Reconnect or repair the contact in the connector.
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
SE error code means a communication problem between the display controls and the main control board. You will need a qualified LG technician to locate and repair the problem.
