Question about IBM ThinkPad T21 2647 Notebook
Battery charging recepticle
The female plug on my charger shorted on the inside. It got real hot and I'm affraid that it may have melted the connections to the male recepticle in the computer as it does not make connection when plugged in. I repaired the charger and tested it on another computer. Works fine. I would loike to access the back of the male recepticle in the computer to see if a connection came unsoldered that I might resolder it. How do I gain access to this? it is a thinkpad 2653
  • 188 Answers
Here is a link to the IBM manual - warning what you want to do is probably a complete teardown of the machine and soldering equipment.
You may want to buy the power jack before taking it apart.
Try they have the right one.
Posted on Dec 28, 2007
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the...
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
May 13, 2014 | Samsung Rv511 Series Laptop Intel I-core...
Hooked up charger sparked melted the plug
Change the XLR PLUG ( three pin male or chassais female are easily found on the internet. Always plug the carger to the mains supply last and remove the mains end plug first when unplugging.
check for shorted wiring inside the XLR plug
Apr 05, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Why would the plug melt on an Acer 5315?
Plugs melt when the connections 'short circuit'.
This means the positive and negative energy paths are touching.
Even the smallest AAA or 9V battery will get really warm if your connect the terminals together, and the power supply of a laptop computer pushes more more power (amps) than a little battery.
If it is indeed the power connection of your laptop has some melting damage, I must recommend you have your laptop and its power supply serviced or replaced, and to not plug it into the wall until you do. Fires have started by malfunctioning/damaged cameras and computers.
I hope that helps.
Aug 21, 2010 | Acer Aspire 5315 Notebook
The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised battery required i'm affraid!
Aug 07, 2009 | Olympus FE-220 Digital Camera
Packard Bell Easynote Charger gets very hot at end
Shorted DC connector in the laptop.
Needs replacement.
Mar 18, 2009 | Computers & Internet
Compaq presario v2000 charging plug melted and will not charge
The problem maybe with the electrical circuit. Find an electrician to check it.
Mar 18, 2009 | HP Compaq Presario v3000z Notebook
The battery does not charge anymore ,the bios setting says idle
remove battery and reseat.
Use VOM (Volt-Ohm Meter) and phsically check to make sure the power supply is putting out advertised voltage (typically 19-20 VDC)
Make sure power supply recepticle (the female part on the laptop itself) has not been broken or reamed out such that contact is not being made.
When you plug power supply in, does the charging light on the laptop come on?
Mar 07, 2009 | Dell Latitude D600 Notebook
Carefully read across two pins, without shorting to the case or other pins. You should have 1 hot, one ground, and usually another ground that acts as a charge inhibit to keep the scooter from driving while charging. I would expect to see around 27 Volts DCX on the output, maybe more without a load attached (battery)
Jan 25, 2009 | Electric Mobility Power Electric Scooter...
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
IBM ThinkPad T21 2647 Notebook Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
