Dvi output on sound card'
I have a geforcefx agp8x card i got a new 22" wide LCD monitor which has a dvi-d output on it The cable has 2 sets of 9 pins + a flat pin What card do i need to use the dvi connection and will there be much difference vs the d-sub signal cable that i am using now?
  • Brewster11 Dec 28, 2007
    But nobody is answering his question about if there is much difference in the video by using DVI-D VS. the d-sub signal cable!!
    President:
  • 1,944 Answers
DVI connections only transfers video (it's not like HDMI). You can continue using your current soundcard to output to the LCD monitor.
Posted on Dec 27, 2007
  • 1 more comment
  • Damen Wong
    Damen Wong Dec 27, 2007
    Connect using a DVI cable from the DVI output of your graphics card ot the DVI input of your monitor for the video. Then connect your soundcard to your monitor with another cable (whatever is available).
  • Damen Wong
    Here is how a DVI connector looks like.
    You mentioned that your monitor has a DVI input...you need a graphics card that has a DVI out...
  • Damen Wong
    Damen Wong Dec 28, 2007
    Technically the DVI is better than D-SUB since DVI is a digital signal and D-SUB is an analogue signal. However, the difference between them is seen more on larger screens with higher resolutions. On smaller, lower resolution screens, the difference is very hard to see. It also depends on your personal taste. I know people who don't demand much and see no difference and I know people who demand much and they see a difference when I don't see a difference. I would suggest if possible, go to some shop that has two screens side by side, one with DVI and the other D-SUB abd then youi can see for yourself. I personaly would go for DVI for a 22 inch screen.
I need to plug an HP f2105 monitor into an HP elitebook laptop
Elitebook has a vga port with is 15 pins. If the monitor only has DVI you can get a VGA-to-DVI-A cable. They are cheap and available on monoprice.com Make sure the monitor supports DVI-A
Make sure to check the DVI port on the monitor for the wide horizontal pin with two small pins on top and two underneath. See pic below.
Dec 03, 2012 | HP f2105 21 inch LCD Monitor
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
How to connect 3 LCD monitors to a computer
Some cards can send 2 outputs that is split by the cable, which is connected to 2 monitors. Generally speaking though, most just split the image up
If you're not sure if your output supports multiple monitors off one output, it's almost certain it doesn't.
There is USB 2.0 to DVI, HDMI and VGA Multi-Display Adapter
resolutions of up to 1600 x 1200 Allows for effortless multitasking
Jan 05, 2010 | Dell DimensionTM E520 PC Desktop
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
Cannot get sound using dvi cable
DVI is digital VIDEO interface, you will need a seperate cable for audio
Jun 15, 2009 | HP w1907 LCD Monitor
DVI connection
Did you try your monitor with another output (VGA)? If not, try it.
So, you have to check and make sure where the problem is (display card, monitor, or cable). Try with another cable or monitor. This way you will know where the problem is. If you don't have another monitor, try the monitor you have with build in VGA output on motherboard by taking the display card out.
Thank you,
Tan
Mar 04, 2008 | LG Flatron 295LM 22" LCD Monitor
DVI ourput on video card
You want the card?
check the marke for a card with DVI out.
there is no such special card any1 you can afford.
Dec 27, 2007 | Computers & Internet
Connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Nov 15, 2007 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
148 people viewed this question
Alun Cox
David Payne
David Payne
