i bought a used motor without the wiring harness or plugand just need to identify the terminals on the plug on the side of the motori bought a used motor without the wiring harness or plugand just need to identify the terminals on the plug on the side of the motor
You can't post conmments that contain an email address.
The short circuit may be located in the junction box from which the dishwasher gets power. Its probably bare wires touching under the "skirts" of two wire nuts.
If no power problems, then the dishwasher itself has a short. In this case, start locating the short in the little box to which the power cord is connected - these connections will short if one of the hot wires, or a hot wire spade lug is touching a frame ground (all components of the frame are grounded).
A third (remote) possibility is a wiring mistake - the dishwasher hot & neutral could be connected, causing a dead short.
When your microwave oven has power, the fan runs, carousel turns, light comes on but the unit does not heat up you have a bad high voltage diode, bad filter capacitor or a bad magnatron in that order. The diode and capacitor do not cost very much. You can get them at www.mcmelectroncs.com or www.repairclinic.com . Replacement would mean removing the unit from under the counter (if not a tabletop unit) and removing the case. Locate the diode and capacitor. They should be near the power section behind the transformer and display. The diode is attached to the chassis on one side with a screw and on the other end with a spade lug to one side of the filter capacitor. The diode is brown and has an arrow on the side. The filter capacitor is a large oval silver can with two spade lug connections on one end. After replacing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive, but depending on the cost of your unit, it may pay to replace it. You should be able to get the magnatron at www.repairclinic.com . The magnatron replacement is not difficult. About four screws and several wires on spade lugs. Just be concientious or mark everything for correct reassembly. Also make sure the part is correctly installed and all seals are in place. You do not want microwave energy to leak out.
may not have a selonid problem. You also have a clutch/brake switch, a seat switch, and a pto switch. If any of these are defective, you will have that problem.
On your selonid, near the bottom, there is a spade lug, use a wire from the postive of your battery to that spade lug, if you hear it click, selonid is ok and you have another problem.
There will be a wire on that spade lug from ingination switch, remove it for this test, then put it back on.
You could also have a defective ingnation switch.
Had similar problem with my oven.
Turn off the breaker to the oven/range and remove the panel which exposes the controls. You will probably find a burned spot on the pc board.
Mine was where a spade lug plugged a wire to the board and caused by a loose connector at that lug. I hard wired/soldered the wire to the board (new board was $200+) and the repair lasted several years.
Open the dishwasher
Remove door panel
Look for a switch with 2 spade lugs attached
Make sure the 2 wires are not broken or corroded
Use a tester to verify switch opens and closes.
replace switch and your problem should be solves
