Question about Kenwood KVT-617DVD Car DVD Player
Kvt-617 bypass Is there a code to the unit, like jensen if u put a code in u can watch ur dvd while driving.
  • Anonymous Mar 02, 2008
    has lock code
U can wire the safety wire to a ground or to a switch that grounds the wire and that will bypass it.
Posted on Jan 01, 2008
Dont know the security code for kenwood kvt 617 dvd unit how can i unlock the code
a new eprom chip has to be installed,and proof that you did not steal the set.
best way for your tv not to get stolen is to leave a post it note that it is locked.
it is like passwording a computer,the hard drive needs to be formatted.
Aug 22, 2009 | Kenwood KVT-617DVD Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
Hideaway brain unit on my kenwood KVT-617 doesn't work
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
timsterp99999@att.net
May 29, 2009 | Kenwood KVT-617DVD Car DVD Player
Need a kenwood kvt-617 brain.
Hi someone stole the head unit out of my car but left behind the brain and wiring.
Apr 17, 2009 | Kenwood KVT-617DVD Car DVD Player
I can not watch the videos and movies in my Kenwood KVT 617 DVD
hi there
on the back of this unit is a green brake wire you need to buy a 3 pined toggle switch ...........you need to take a small but mid size length speaker wire and attach to 12v (red wire) going into back of kenwood unit add another speaker wire to the ground wire (black wire) of kenwood unit... now on the 3 pined toggle switch add the power speaker wire to the toggle switch add the ground speaker wire to the toggle switch once this is done add the green wire to the last toggle switch pin........put the kenwood unit back in dash.......now turn the car and toggle switch on...........put in a DVD and if screen shows DVD all is done...... but if the screen does not show the DVD......just switch the green wire with the black wire on the toggle switch and now it should work
hope this helps
Mar 02, 2009 | Kenwood KVT-617DVD Car DVD Player
Dual dvd stereo bypass
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 11, 2008 | Kenwood KVT-617DVD Car DVD Player
Video
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 20, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt-719 brake bypass code needed
I've never seen a code that allows it, but you can do it in the wiring harness. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 15, 2008 | Phase Linear UDV9010 Car DVD Player
Kvt-617 dvd receiver hideaway unit
go to e bay n look 4 someone selling a brain/ hide away unit for cheap..????to use with ya dvd unit.
Apr 20, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD Car DVD Player Logo
242 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
