battery quit on me,screen will not come back up. start the computer in all safe modes and in last known good configuration and have a blank screen.
Please help
David
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp. To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: - www.lcdparts.net
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if...
(More)
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if its software i have to download or its internel and i cant find it in my control panel
i have changed computers and am unable to access jigsaw puzzles purchased in the name of...
(More)
i have changed computers and am unable to access jigsaw puzzles purchased in the name of morag.milne@dsl.pipex.com when i type in reg key it is refused and i am unsure whether i should type the number"0" or the letter"O"
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system...
(More)
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system menu but then image error pops up with a black screen. cannot use laptop i think i may have lost data. pleeeeaaaaase can somebody help.
