Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Green....purple....colors Hello....I have a Panasonic PT-53w x 52 built in 2003....When I turned on the set....What appears on the screen is this....The image is double...along with the colors green and purple being arched on the bottom....Can i fix this..?
  • saaaa Jan 09, 2008
    Same thing except Sony could this be related to magnetized it is a projection tv
  • GallitanDave May 11, 2010
    MY PT53Wx52 is displaying the same convergence problems. The menu adjustment does not help. I'm preparing to order the 2 IC's and solder pen, and other items. Can you confirm the following:
    1> I should not use a high wattage solder gun. Instead a solder pen with low watts. What other tools should I have handy for this project?
    2> Do the new IC's come with the white substance between the IC and the heatsinks? What do you use there?
    3> Would you order replacement resistors when the new ICs are ordered or just gamble on them being ok?
    Thanks..... great site!
    Genius:
  • 1,694 Answers
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Posted on Dec 29, 2007
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic 52 in cianema vision how to make second channel appear in corner
I turned my tv on one day and the screen just went to like times 100 in size so i replaced the bulb not the problem how do i fix it
Nov 02, 2008 | Panasonic PT-52DL10 52" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Hdtv projection monitor (pt-53w-42h panasonic
bad convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 21, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Oct 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
