89 jetta carat has separated a part of the framework of rubber of the door of the passenger I want to know if is that I can adhere that part and with which or I have to replace all the framework of rubber
If the weather strip has come away from the door and is not torn you can glue it back in place.
Contact cement will do it as will good quality double sided foam tape.
Hope this helped. Please rate if this helped you.
Pick up some weatherstrip adhesive at a parts store. 3M. and just be maticulous in the repair. Don't get any on the surface that seals up against the door frame. Silicone spray will keep the weatherstring from aticking and getting torn because of the door being closed too long in hot weather.
Use weather stripping glue check with auto zone
