Question about Jensen VM9510 Car DVD Player
Xdvd700 bypass code
Do you know the bypass xdvd700 code
  • 2 more comments
  • GABBY COSTA
    GABBY COSTA Dec 29, 2007
    display it says "caution its unlawful to operate a vehicle while videois displayed in the drivers viewing area engage emergency sequence to enjoy" so i guess i need a code to play it which i cannot find
  • Anonymous May 05, 2008
    how to get code for the xdvd 700
  • Anonymous May 08, 2008
    so what is the code
  • miguel801 Oct 10, 2008
    ah los code
How to get code xdvd 700 for dual model
Posted on May 05, 2008
Put a DVD in and let it play *** soon as you  hear sound  press stop 2 times on your control and hit 26604 and then hook the e-brake wire to the back screw and it should work.
Posted on Oct 28, 2008
  • 3 Answers
The way you bypass the E Brake is you have to ground the wire to the radio sleev itself. There are two different peices. The radio itself and the sleeve that holds the radio in place. Take the yellow wire (the ebrake wire, not the yellow ignition wire) and open the metal connector up just slightly. Attach that wire to the top of the sleeve on 1 of the teeth located near the front of the unit. You have to make sure that the connection is good or it will not ground. Next slide the clear plastic over the wire so the only connection is with the tooth.
Then Insert a cd or dvd in the player. Press play on the remote and then push stop 2 X times on the remote. After you have done that press 26604 on the remaote and then press enter. This will permanently unlock the parking brake feature and allow you to watch dvds while in motion. If you need any further help you can eamial me at casey_eaglin@yahoo.com
Posted on Sep 08, 2008
  • casey_eaglin Sep 08, 2008
    The anti theft default code is 0000. If you have any other questions feel free to email me at casey_eqaglin@yahoo.com
I have a xdvd700 and replaced battery in truck have a picture but no sound from unit. tried resetting code and still have picture.
Posted on Aug 05, 2009
Which one is the back screw
Posted on Oct 29, 2008
Try 1264 for the xdvd700
Posted on Sep 01, 2008
I cant get the antitheft code off my dual xdvd700 i took the battery out now it shows code someone please help me
Posted on Jul 22, 2008
How to get code for xdvd 700 for Dual
You haft to get a toggle switch hooked up it tricks the emergency brake wire makes it stay on even when driving
Posted on Jan 01, 2008
Just ground the pink wire and it will work
Posted on Dec 29, 2007
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
Dual xdvd700 has been locked, broken remote, blue screen
you have to press the reset button then it will work
Sep 17, 2009 | Dual Car Audio & Video
I need the master unlock code for the dual xdvd700
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Sep 04, 2009 | Dual Electronics XDVD700 Car DVD Player
Video bypass for dual xdvd700 without remote
i used a switch, to the ground, and i'm still having problems, so yeah lol
Jun 17, 2009 | Dual XDVD8181 Car Video Player
Dual xDVD700 won't come on
CHECK VOLTAGE ON RED AND YELLOW WIRES OR RESET THE UNIT.
May 13, 2009 | Car Audio & Video
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Dual audio XDVD700
Try playing a DVD Press Stop Twice Enter 26604 Press Enter
Dec 21, 2007 | Car Audio & Video
Dual xdvd700 want to permanently bypass e-brake
1. Ground the E-Brake wire.
2. Insert a DVD
Let it play until you hear sound
Press STOP twice on remote
Enter 26604
Press ENTER
Oct 27, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
1,328 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
