Question about Hampton Bay (261025) Dual Mount Ceiling Fan
Problem with Light
Have hampton bay E106510 3-speed with light.
Light quit working.
Replaced bulb.
Replaced (optional) wireless controller.
Blue wire leads test positive for continuity check.
Took fan apart. Notice wiring from lamp socket (white wire) is connected to
a capacitor? SH-Cap. 4uF 300v.
Could that possibly be defective?
  • JohnCFixya Dec 28, 2007
    Problem with light solved.
    By locating and issolating white (neutral) wire from light circuit, i found a defective socket. The metal connector for the positive (blue) circuit wire had lost is original form and colapsed inside it. I was able to pull it out with needle-nosed pliers.
SOURCE: hampton bay ceiling fans
Take the socket (or bulb) to an electric supply store. Tell them you need one (or one that fits this bulb).
Posted on Sep 05, 2007
  • 709 Answers
SOURCE: Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Posted on Nov 30, 2007
  • 20 Answers
SOURCE: wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Posted on Jun 17, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
I have a Hampton Bay fan and light fixture. The fan works using the switch., the lights do not come on at all, withe either the pull chain, or the remote. There is continuity from the source to the...
You might check to see if the blue wire is connected on top in the canopy and check if you have voltage coming out to your light kit at the wire connection with a meter. Careful with the power.
Aug 25, 2011 | Hampton Bay 52 In. White Redington...
Replaced 2 of 4 bulbs with 75watt bulbs. It sparked upon turning on the light and now the light does not work at all. Fan still works????
In the cealing where the fan is mounted, you have wires in the switch the control the fan speeds, to the motor and wires that control the light. Most likely there is a wire exposed or short that every time you turn light on, it of course blows light out. Als check , open up switch on wall first to make sure no loose wire on wall switch. Please turn of breaker first, make SURE power is off. Please if this advice helped, give me 4 thumbs to help me and others, thanks, Mike
Jun 16, 2011 | Hampton Bay 48 In. Palm Beach in Textured...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
Receiver quit. replacement has just one wire and a
all of the white wires connect together and to the white house wiring ... the black of the house wiring goes to the AC input of the module (may be a black wire ) .. the blue wire from the lights goes to the light output of the module (as you already know) ...
now the motor actually has only two wires .. one white that should already be hooked up with all the other white wires .. the other goes to a block that contains the speed controlling capacitors .. and that has the 4 wires (you metioned cominng from the motor) .. the capacitors are no longer needed since the speed control inside the module takes over .. so you can eliminate the capacitor block (thats normally connected to the speed control switch that you wont need either)... that will leave you with just one wire from the motor that has to be connected to the modules motor wire output ... that should do it ... set the code on the module and remote the same (in battery compartment of remote) (good idea to make sure your neighbor isnt using the same code ..
connect the green wire (or bare wire) to the metal of the fan ..usually a green screw or a bare wire .. thats the safety ground ..
May 27, 2010 | Hampton Bay 24002 Ceiling Fan
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Model#666834 speed switch wires fell off switch. Need location of wires on switch? L,1,2,3, white,black,yellow,blue.
blue wire came off for the light and i would like to know which set it connects to. when i put it back with the blue wires , the fan controls the light. please help.
Aug 01, 2009 | Hampton Bay Dryers
My Hampton Bay 54shrl which has two wires only an a remote,the problem is the remote seems to work find and then it does'nt I disconnect the wires reconnect and then it works for a while I'm Baffled can...
We have four models range 54SHRL Hampton Bay three of which face problems in speed. We try to raise it in the remote and just stay at the slower speed. What can we do?
Jul 06, 2009 | Hampton Bay 52 In. White Redington...
Fan works but no light
Your receiver is shot and must be replaced. This is a small black or grey box two inches by four located under the cieling mount cover.
good luck---------------tomtaso
Dec 14, 2007 | Hampton Bay 46056 Callaway II Ceiling Fan
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
You have a dangerous electrical situation call an electritian to test the wiring.
Oct 20, 2006 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay (261025) Dual Mount Ceiling Fan Logo
156 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
