Question about SanDisk Sansa e260 MP3 Player
Knocking out desktop mouse and having to install restore software once plugged into the usb 2.0 port
Help with the above
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
My front usb ports on my computer suddenly stopped working. I do have vista, and I swear the problem arose after an update. I can plug my ipod into them, and it charges my ipod, but it does not open...
Go to Start-Programs-Accessories-System Tools-System Restore and back your computer's date to some time before you installed this update. You will then know if the update actually caused the problem.
Sep 21, 2009 | E-Machines eMachines Desktop PC
USB device not recognized
Got the easiest solution to the problem. It worked for me, hope it helps all of you too.
First of all, if the device is unrecognizable, go to Device Manager and remove (not disable) the device. After doing so, remove the USB connector from the port.
Next, go to
http://www.logitech.com/en-my/support-downloads?wt.mc_id=usym_redirect_/index/downloads, and look for your mouse/keyboard etc model. Choose the one that you own and choose the Software Downloads option. Next, follow the steps and install the Logitech Connection Utility.
Once installed, follow the steps given and hopefully your device should be reconnected once again. Hope it helps all the best!
Sep 13, 2009 | Computers & Internet
After rebooting my cpu my mouse stopped working. My cpu does not recognize my mouse? The mouse works because i tried it on a different cpu. what can be causing this?
Did you try to reboot?
Do you have an optical mouse? (if yes: is the red light on?
(Then the mouse is recognized and you must configure your mouse options)
Did you try to connect your USB mouse to another connector?
Or if PS2 connector: Turn of the pc and connect the mouse and power on.
Did you install a new driver? (then uninstall this driver)
Try looking for the most recent mouse driver on the manufacturer site.
Jul 13, 2009 | HP Pavilion a1610n PC Desktop
How do I connect my wireless mouse?
a wireless keyboard or mouse mostly works in pairs and has a transmitter which normally should be connected to the computer's usb port. you may need to install the mouse driver depending on yuor OS. once this is done the mouse should automatically connect.
Jul 11, 2009 | Logitech Cordless Desktop EX110
PS2 keyboard mouse not functioning
First look usb or pst driver is stall or not. if install your port may be damage or shourt. then check usinge y- cable. where one side usb port and another side we get ps2and usb. then we use mouse and key board once atime.. . ithink u solvev your problem. if not .there is another way . you can add usb card in *********** bord . Which help you to operate usb key board and mouse once time. thanks
Jun 17, 2009 | Acer Aspire™ T180 PC Desktop
Keyboard want light up but mouse works
The buttons on the top (silver) are linked to your "Favorites" folder in Internet Explorer.
The buttons to the right of that are used for your media player (To skip tracks and adjust volumes, play pause etc)
The buttons on the left (from top to bottom) are:
1) My documents folder will open
2) MSN or Windows Live! Messenger will open
3) Your E-Mail will open (whatever your default email program is)
4) Calculator Opens
5) Windows Update will open
Now... In order for these you HAVE to have the drivers installed. If you didn't get a CD with your keyboard, you can download the drivers directly from Microsoft here:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Just fill in the drop-downs and press "Go", it should show you a link the the exact driver you need to install. Once it's been installed you can set up your favorites with the software that it installs.
Oct 24, 2008 | Microsoft Wireless Optical Desktop Comfort...
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Mouse wont work
You mouse does not work? First few things I would check is make sure your mouse is plugged in all the way if its a ps/2 style mouse check to make sure none of the pins are bent ps/2 style is round. If your mouse is usb try moving it to another usb port also make sure the mouse drivers/software is installed
Aug 12, 2008 | E-Machines etower 500is PC Desktop
I have a logitech laptop mouse, i have it plugged in to the laptop USB port (wireless) with a new battery in the mouse and its not working. it was working a few days ago, but then it just stopped. do i...
Do you have the software to go with the mouse or was there one at all?.............you may need to reinstall this software. Otherwise if you did install it and for some reason it cease to go you may need to restore your machine from safe mode to a day when it did go..................regards Peter
Jul 14, 2008 | Computers & Internet
SanDisk Sansa e260 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
