Question about Nokia 6233 Cellular Phone
Cell phone video input
Can i use mini lcd displays from cell phones with external video signals? I'd like to use them in a sculpture project as windows in a building and send video signals, in proper resolution, to them. Looking for some help hacking theses.
IF yes, is there a format I need to use for video signals, can I convert the connections to simpler, less fragile ones, like RCA?
  • 76 Answers
No you can not use your LCD screen for that purpose. sorry. Hope this helps =)
Posted on Feb 25, 2008
Sir in nokia 6085 mini lcd no light , I already changed mini lcd problem same
Thanks for your question. First i have to need to know had you reinstall your phone operation system? that means flash system. but you said you changed your lcd display. that means you hadn't no lcd fault. i think in your mobile motherboard capacitor or diod problems which block your lcd displaying system. please consult in your near any professional technician. thanks
Apr 04, 2011 | Cell Phones
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
Why does my emerson tv stay on standbye mode
Do you mean the power switch does not shut it off, or do you mean it does not show the signal you want it to show?
I can't help you over it not turning off, but if you are not seeing the signal, it may be because the TV has various alternate inputs, and has to be switched between which one you want to show, such as:
2 x HDMI input ( 19 pin HDMI Type A ) - rear
1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - rear
2 x S-Video input ( 4 pin mini-DIN ) - rear
1 x audio line-in ( mini-phone stereo 3.5 mm ) - rear
5 x audio line-in ( RCA phono x 2 ) - rear
2 x component video input ( RCA phono x 3 ) - rear
2 x composite video input ( RCA phono ) - rear
Try using the on screen menu to bring up a choice over which input to show.
Switch it to the one you have connected to it.
Feb 13, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have a Dell Inspiron Mini. When i turn it on the desktop wont show. All i get is a black screen.
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 22, 2010 | Dell Inspiron Mini 10 Notebook
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
Audio line-in ( RCA phono x 2 )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Display
Can not display what? Video? It should once in vtr mode. If it still does not work are you still getting signal to the LCD when recording? Does it Show on the LCD when connected to final cut? If you are getting any signal to it, it is a setting, prob mess with the video out settings, if not hardware.
If you want to display the info, try turning title on also turn character display off and on.
Aug 23, 2008 | Sony DSR-25 Mini DV VCR
External Display Screen
you just need to get the external LCD replaced...not to worry most lcds on the v3 you can take out the external lcd without replacing the entire lcd....so take it to a repair center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
Nokia 6233 Cellular Phone Logo
274 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
