Home | Sharp | AL-1642CS Copier | Making clicking noi...
Sharp AL-1642CS Copier
Problem for Sharp AL-1642CS Copier
Making clicking noise when turned on..folding
By identifyingm on Oct 16, 2009
making loud clicking noise when turned on.. folding paper up ..
Solution #1
posted on Oct 16, 2009
Not Rated)
Copier_God
Rank: Guru
Rating: 88%, 10 votes
A scraper/s have either;
1) Popped out of their location..
2) Damaged your upper heat roller/lower hear roller and the click is where its steadily wearing into the surface of the roller.
You can do the following;
Remove the power cable.
Open the covers so you can access the fuser (the hot part)
Look inside, you will be looking for about 4-6 scrapers, they should look like a birds beak (kinda)
See if you can remove the one causing the problem, if not, get the copier to jam up then look in there, the one causing the issue should stand out as it will be causing the jam.
All in all you will have to remove/or re locate the scraper into its original position.
Was this helpful?
Yes
No
Popular Solutions for Sharp AL-1642CS Copier
Questions and Unsolved Problems for Sharp AL-1642CS Copier
Do you recommend Sharp AL-1642CS Copier?
Answer
Answer
Brother phone/fax 1960C will not print incoming faxes---where can I get repaired &/or... (More)
Answer
error 320
Answer
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant... (More)
Answer
adf adjustment for sharp copier AL1642cs
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL-1642CS Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
