I'm not sure about the model number, but when I close the frig door and the freezer door pops open, it sometimes doesn't close tightly. Twice, I got up in the morning to find the freezer door ajar, motor running, and frosted freezer ceiling and food.
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Leave the door shut and let the magnetic gasket hold the
door in place. Put something between the bottom of the doorand the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking
note of order of removal of parts. Slide new cams on. You probably need two.
My GE refrigerator is getting too cold and freezing items in bottom of refrigerator and toward the...
(More)
My GE refrigerator is getting too cold and freezing items in bottom of refrigerator and toward the back of the refrigerator and freezer not getting very cold. Freezer is on top.
Freezer working good. Frige not cold. The cold setting for frige not lit up. When I turn frige cold...
(More)
Freezer working good. Frige not cold. The cold setting for frige not lit up. When I turn frige cold seting down it does turn off & when turned up you can hear it running . set at cooldest setting & still not very cold.
hi, i defrosted fridge the other day all was fine when i plug it back in a few hour went by and it...
(More)
hi, i defrosted fridge the other day all was fine when i plug it back in a few hour went by and it stopped working now it keep trying to kick on an then off it is an older model but i dont think it needs to be trashed yet?
My GE refrigerator freezes meat and ice cream but not ice cream. The warranty has expired. Has...
(More)
My GE refrigerator freezes meat and ice cream but not ice cream. The warranty has expired. Has anyone else experienced this problem and/or has a solution. Thanks.
