Question about Panasonic AG-DV2000 Mini DV VCR
Panasonic dv2000 I am using one of your dv tape decks to import video into Final Cut Pro using the firewire400 port, and for some reason the deck keeps dropping frames.  I don't know if just cleaning the unit would help or not.  Any ideas as to the problem?
    Champion:
  • 221 Answers
Cleaning is a good first step. If cleaning the deck doesn't work, it may need a tape path alignment.
Posted on Feb 06, 2008
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
Mar 02, 2010 | TDK DVM60 Mini DV Tape
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
My JVC GY-HD111E isn't located in final cut pro
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Mar 28, 2009 | JVC GY-HD111E Mini DV Digital Camcorder
Drop-out glitch with Fuji mini-DV tapes
Unfortunately, the outlook is grim. If you duped the tape and the dropouts still appear, the anomalies are regrettably on the master itself, or the DSR11 is malfunctioning.
To be sure, try the following: View the master tape on a different deck, if possible. If glitches vanish, problem solved. Connect the AV/RCA out to the input on whatever digital deck you're using, and capture as usual with FCP. (If you need assistance with this step, I'll be happy to walk you through or send you in the right direction) Optimally, for a Hi8 tape, you would capture using DV 60i settings.
If glitches still appear, try capturing audio and video in two separate occurrences, I.E. One capture for video only, and a second capture for audio only. Sync in final cut.
If that doesn't work, your other option is to send the tape out to a post production house/lab, and see if they can do it -  but if you've tried everything else and resorted to this option, the chances are slim that much can be done - Hi8 tapes are notoriously difficult to recover. Best of luck, and do let me know I can be of further assistance :)
Dec 12, 2008 | Fuji E6-120 MEP Hi-8 Tape
Problem with playing large dv tapes
I am very familiar with these decks and I repair them. Contact my business Waveform Audio Video, Martinez, California. Email: waveform@wwdb.org
Paul
Oct 15, 2008 | Panasonic AG-DV2000 Mini DV VCR
DV Deck not loading tapes...wtf
most likely problem is a defective cassette housing. good service tech should be able to handle this with no problem.
Aug 29, 2008 | Panasonic AG-DV2000 Mini DV VCR
Fire connection
Do you have its Service Manaul to check any hardware problem in unit?
Aug 03, 2008 | Sony DSR-1500 Mini DV VCR
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Audio Problem with Firewire
The input select switch on the front of the AJ-D230H needs to be in the "OPTION" position, not "LINE". That may help if all the other settings are correct. You will also have to make sure that you have selected the right codecs for the deck that you are using in the software. I am speaking as a Final Cut Pro user so only offer this as a suggestion as these are the things that work from out of Final Cut.
Good luck. It can be very frustrating, but awesome when it all comes together and works right!!!
Helen
Oct 24, 2007 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR Logo
233 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
