Dell Latitude D600 PC Notebook
Problem for Dell Latitude D600 PC Notebook
Error code unmountable_boot_volume
By tinkaniah on Oct 16, 2009
error code unmountable_boot_volume and it wont let me go into safe mode
Clarification Request
Posted by jcr2 on Oct 16, 2009
Will it boot to your OS cd?
Best Solution
posted on Oct 16, 2009
Very Helpful)
rodietom
Rank: Wiz  Dell Expert
Rating: 82%, 42 votes
Could also be a hard drive issue. Try going to the BIOS and look for the Drive category. Look for SATA Operations and change it to ATA. Save the changes, then exit the BIOS,
Running the Dell diagnostics on the hard drive wll also be a good idea. Turn off the system and then hold down the FN key, then press the power button. This should start the computer and initiate the diagnostics test which should check the hard disk and memory for errors.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
black_pnix
Rank: Guru  Dell Expert
Rating: 87%, 23 votes
-You may try this step.
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude D600 PC Notebook
Questions and Unsolved Problems for Dell Latitude D600 PC Notebook
Do you recommend Dell Latitude D600 PC Notebook?
Answer
Answer
trying to get on texas holdem stops half way
Answer
Notebook Pavilion dv2000 black screen will not boot up
Answer
HI, I HAVE PROBLEMS WITH THIS PP01X DELL LAPTOP COMPUTER SCREEN YOU SEE HOW FULL IS REDUCED TO 9... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
