Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Help! TV will not come on.
When tv is turned on the indicator light comes on and after about 5 seconds shuts off and then on and then off again....will not stay on.
PLEASE HELP!
    Genius:
  • 1,030 Answers
If the idicator light flashes this indicates a processor shutdown. first thing a customer can do is uplug for 30 min and try again. This never works i must admit but it eliminate the processor lockup chance. Now if it still does this then you have a problem the processor has detected a cuircit failure and shut the set down for safety. This also tells you it not a "FUSE" since the procesor is getting power. The processor generates a error log that can be read by a technician and a computer. other than that all i can offer is check for loose connection and if you have any technician experence alway check horizontal output transitor. BE CAREFULL TELEVISION GENERATED DANGEROUS AND POTETIAL LETHAL VOLTAGES.
Posted on Dec 28, 2007
2 Suggested Answers
  • 54 Answers
SOURCE: TV WILL NOT COME ON
Your tv is probably going into a "protection mode" this means something inside the set had failed. This is the tv's way of shutting down before more damage can occur. This could mean many different things that could have gone wrong with this unit. Your best bet is to call your local dealer and have them come out and look at it for you. Tearing apart tv's is very dangerous! Some sets have up to 30,000 volts on the anode! GOOD LUCK!
Posted on Aug 17, 2008
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Receiver LED just turns off in 5 seconds
some tvs have a over voltage or over current circuit protection. this is built into the main circuit to avoid further damage to the tv set. Your tv probably has a switching mode power supply and it's shutting down probably due to an over current condition usually a shorted horizontal out transistor, that is why when you replug the ac cord you get the power light indicator come on for a few seconds then turns off. You may have to take the set in to a tech to diagnose the problem or get an idea on the repair cost.
Sep 09, 2009 | Televison & Video
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Jan 24, 2006 | RCA F27450 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
