Question about Chaintech GeForce 6600, (128 MB) Graphic Card
Digital siginal output probelm
When I upgraded to the latest Nvidia driver , it caused the digital output from the video card to stop working, between the Window XP display Screen and the Welcome screen.
The signal cuts out between those 2 screens.
When I loaded the driver (ver. 71.25) it works just fine.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Check the drivers read me file or the driver INFO main be it wont support the card you are trying for.
i got the same problem with may nVidia card.
also go to setup utility and select the VGA TYPE as AGP Card.
Posted on Jan 06, 2008
Error: "Display driver stopped responding & has recovered.
I too was suffering this problem of the kernel driver stopping responding and restarting. ii have the GeForce 6800 GT card and what I found the problem was, was the capacitors on the card had blown open. 1500uf 6.3v, not just one or two but all four. I replaced them and card and drivers are now working okay.
Apr 29, 2013 | MSI NVIDIA GeForce GT 620 2GB GDDR3...
The display conacted to DVI galaxy card output didn't recognise conection
u need to activate the second port /dvi from the nvidia controlpannel *cpl* if u don'thave it u need to install the latest driver it's emdded on
Sep 19, 2012 | Nvidia GeForce FX 5500 Video Card Graphic...
I have a nVidia Quadro2 MXR/EX video card which works fine on the analog input but when you use the digital input the screen sometimes flashed at startup and then goes blank. If you move the mouse,...
There are a few things that come to mind here. Number one is to try a different and known functioning DVI cable. Maybe see if you can recreate the problem simply by wiggling the dvi cable. If there are any splitters/adapters, remove them and plug the cable straight from the video card to the display. Make sure the display is set to digital input mode. When you are using the digital cable, make sure to completely remove the analog cable. See if this problem happens outside the operating system (such as in the system bios, if it does, this indicates a hardware issue). Finally, the digital input on the monitor could be having an issue, try a different monitor or try this monitor with digital input from another system.
Sep 24, 2011 | HP NVIDIA Quadro2 MXR (32 MB) AGP Graphic...
The screen display looks odd and undersized, and the icons are smaller than usual
Nvidia 9300GS is a well-performing graphics card. Such display resolution problems should not occur. To resolve issues of faulty display, download and install the latest driver of your Graphics Card. Go to Nvidia's official website and get your device's WHQL Version of driver, don't go for the Beta drivers.
Thank You.
Mar 08, 2011 | Nvidia Geforce 9300GS, PCI Express Video...
Monitor will not display . Says to set resolution at 1280 x1024 . I used another monitor and changed the resolution and still didn't work. tried in safe mode, no good
Check your video drivers and the software that supports your video card. I recently did a complete OS reinstall and used the best and latest video drivers. My video card is an nVidia 8800GT. I downloaded and installed the latest software from nVidia. My display works great.
It isn't always a fault with the display. Sometimes you need to have the correct display drivers. A generic driver thqat is not the one you need could be a problem. Also, if you use the correct video sriver for your system, and you don't have the right software installed and configure for your video card, it can also be a problem.
To see is there is an obvious driver issue with your display in XP (I have XP), right-click on "My Computer."
Select "Properties," then "Hardware." Select "Device Manager" and check the list to see of you have an exclamation point beside "Monitor" or "Sound, video, and game controllers."
If everything checks, and you can confirm that your drivers and applicable software are up to date, and settings are all good, it is not software or drivers.
Hope this helps!
Steve
Jan 06, 2011 | Princeton Digital VL173 Monitor
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
Problem installation video card
Hello Virna, i have that exact graphics card and dell GX270 desktop here at home, tho it has been awhile since i removed the Nvidia PCI card for a more favorable AGP card. From what i remember, first check your BIOS (hit F2 on startup) and select integrated devices, scroll down and make sure your default video output is either PCI (if available) or AUTO) exit saving changes. If that yields no result. Plug in a second monitor to your old integrated video output, if you can view windows after bootup from there, then you can install the proper Nvidia display driver for windows Xp (available here: http://www.nvidia.com/object/winxp_175.19_whql.html ). After installing, right click on the desktop, select properties, display settings tab, and make sure the Geforce card is the main monitor and the desktop monitor. Click apply, unplug the integrated VGA output, and restart. Hope this helps.
Apr 03, 2009 | Evga nVIDIA GeForce FX5500 Video Card,...
Display Drivers
If you right click on the wallpaper and go to the VC Conrol Center, you will see 2 vc, one with the normal resolution and other with 600x400 and 8 bits. This is perfectly normal
Aug 26, 2008 | Computers & Internet
My system crashes all the time. It locks up, reboots itself, goes blue screen and crash dump... most of the time it just locks and the only solution is to power down and back up again. Sometimes I get...
the solution here is to uninstall nvidia graphic driver and buy an external graphic card and install this if you are running on the on board one this has problems with resources and memory shareing.
Make sure you have got 128mb or above on board and directory x10 plus pixel shrader for video playback an do a virus scan as well plus a spyware sweep.
and if you are running xp this also can cause problems upgrade to vista premium for dual core boards as this dual core systemboards are more designed for vista then xp.
good luck on this one
Jul 08, 2008 | Acer Computers & Internet
Chaintech GeForce 6600, (128 MB) Graphic Card Logo
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
