PC won't start. Unit is getting power but fan won't turn and unit clicks. When I unplug drives and peripherals, the cooling fan will run, but the PC won't power up. I suspect that the power supply is bad.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
First of all unplug the unit for at least 30 minutes and let the compressor cool off. That clicking your hearing is the "KliXon" thermal overload trying to protect the compressor because it is not starting.
Failure of a compressor to start can be caused by several things.
1. A bad PTC Relay / KliXon mounted on the compressor
2. A bad run capacitor
3 The bad news... a LOCKED rotor in the compressor.
There is one other possibility and that is that the power cord plug is not making good contact with the wall outlet terminals. (very rare that this happens)
Just make sure to unplug the unit for at least 30 minutes. Use a fan for cooling the compressor if you can by just pointing it toward rhe area of the compressor. After 30 minutes plug the unit back in and cross your fingers...... If it starts your in luck... If not then your going to need to service the unit.
Again thanks for using Fixya and if you need further assistance just reply here. We get notified of all responses. Kelly
Probably a problem with the power module. Unplug it and lit is sit for a while then plug it in and see if it corrects the problem. If not just look at the back of the computer.
where the power cord enters,and see if the fan is going.
if there is any unlit led there. If it is unlit.
Or if the fan is not going., you may need a new power unit.
Remember that most computers have more than one fans. Look for the fan that cools the power unit, Not the one that cools the CPU or video cards.
They are lower down. and since these fans fan does not always have to run continually.,.
First of all, DO NOT unplug the unit until the fan stops. The fan should continue to run until the lamp has cooled down completely. This is normal. If the unit is shutting down on its own, perhaps the fan is not working good enough. Check for debris in the fan area and be sure that there is enough ventilation to keep the unit cool. The shutdown may be a safety shutoff because of heat.
Check the fans and update this with what you find.
Try unplugging everything you can from the computer. Only leave keyboard, monitor, and power cables connected. Then try to turn on again. If computer boots now, then start adding peripherals back one at a time, rebooting each time. when you get the hang, there is your suspect peripheral.
Also, is the monitor itself having issues, or is it the computer? Look at the power light on the monitor, is it staying green, or is turning back to same color when it is in standby state?
