Question about Maytag SAV5710 Top Load Washer
Washer died My washer was washing a load and when it went into rinse it died. Acted like a breaker tripped, no power, finger faucet doesn't work. Re-set breaker numerous times. Plugged washer into extension cord from another circuit. No response from washer. What now?
  • cwwv Mar 22, 2008
    It sounds like I have the same or similar problem--the breaker tripped. I flipped it back on--but don't know hwat caused the problem. Model MAV 8757AWQ.
  • amerkle Jul 21, 2008
    Washing machine just died. complete power fairure. Re-set circut brackers, No luck. Replugged to a working outlet, no luck. Matag SAV5710AWW
    Scholar:
  • 196 Answers
Need a little more information. Need model/serial number and age of the machine before attempting to troubleshoot.
Posted on Jan 02, 2008
I got 2 wascomat gen5 that trips breakers only on rinse cycle
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Mar 17, 2015 | Washing Machines
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Lost power to washing machine
When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
Jan 04, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Washer trips breaker when it gets to spin cycle
The motor has lost the ability to turn the one way. when it tries to turn in that direction it cannot and draws high amps which kicks the breaker...
washer mootrs go one way for the wash but the other way for the spin...
This tip will explain it in more detail...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 05, 2010 | Kenmore 24032\24036 Top Load Washer
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
WASHER AGITATES WHEN SUPPOSE TO SPIN
Faulty spin windings on motor. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag SAV5710 Top Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
