Question about True GDM-41 Refrigerator
Help? Ihad true- Self Contained Glass Door Display Coolers it has 2 plugs. When i pluged to outlet it makes noises and power strips How can ifix that problem?
    New Friend:
I have a true cooler model GDM-41 and its freezing the food inside what do you guys think.
Posted on Dec 04, 2013
  • 122 Answers
Turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Posted on Sep 23, 2009
3 Suggested Answers
SOURCE: The interior light is off
You need to see if the refrigerator is plugged in properly. Also check for a blown fuse or tripped circuit breaker. See if there is any damage to the electrical cord and check the outlet voltage. Troubleshoot the problem and if you do not find any of the above reasons as the cause of refrigerator not working, call the repairman.
Check for the temperature control. If it is off, turn it on. If not, then you need to check the compressor for overheating. You need to unplug the refrigerator and clean the condenser coils. If the compressor is bad, then you need to call the repair man.
Also, You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
Take care.
Posted on Sep 01, 2010
espressonist
  • 1711 Answers
SOURCE: In a True 3-door self contained pizza table,
Professionals they use a special steel wire spring which they insert in the drain tube and it can be clean perfectly and very easy. This steel wire spring is the same that the electricians use to pass the cables through the conduit pipes and it can be fint at electricians shop or DIY. At DIY they have also a similar one specialy for drains. Also you can use a steel wire rod but the problem is very difficaul to pass from curves. If the drain have ice then you can do again as professionals do, use a hair dryer to the are around drain tube and this will melt all ice.
Posted on Sep 07, 2011
Brother 7840 MFC blank stripe down every printed page
1. Turn off the machine's power switch. Unplug the telephone line cord first, disconnect all cables, and then unplug the power cord from the AC power outlet.
2. Lift the document cover.
In the ADF unit, clean the white bar (1) and the scanner glass strip (2) under it with a soft lint-free cloth moistened with water.
Note
In addition to cleaning the glass strip with a soft lint-free cloth moistened with water, run your finger tip over the glass strip to see if you can feel anything on it. If you feel dirt or debris, clean the glass strip again concentrating on that area. You may need to repeat the cleaning process three or four times. To test, make a copy after each cleaning.
3. Plug the machine's power cord back into the AC power outlet first, and reconnect all cables and telephone line cord. Turn on the machine's power switch.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 27, 2014 | Brother MFC-7840W Multifunction Laser...
Pc turns it self on by it's self
Make sure the power button isn't sticking at all. If it is sticking then use some glass cleaner on a cotton swab and clean around the button.
Try plugging the computer directly into a wall outlet instead of a surge protector or power strip to rule out a faulty product.
If the same thing keeps happening then you'll need to replace the power supply.
Jan 12, 2012 | E-Machines eMachines Desktop PC
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Describe your Epson im- 700 pos machine com portProblem Hi, We have IM -700 POS now its getting problem with printer and display. Showing com port error code 1001 pls any body can help
    If you are getting display problem then
    1. Make sure your display (moniter, CRT, LCD, screen, whatever you prefer to call it) is plugged into a wall outlet or power strip and powered on. Also ensure that it is securely plugged into the back or bottom of your display. Many displays do not have removable power cords, making them more prone to shorts and other damage. Check your cable to make sure it isn't damaged.
    2. Make sure the power strip or wall outlet that your display is plugged into are functioning by plugging another electrical device, such as a lamp, into it and switching it on.
    3. Check the connection between your computer and your display. Make sure that it is completely plugged into both as well as fastened with the attached screws.
    5. To double-check any possible cable problems, if at all possible, swap out the screen's power cord and the cable connecting your computer to your display.
    6. Swapping out your display is also a good way of narrowing down the problem. If you get the same result with a different display, then you can be near positive the problem is something in your computer. If switching displays fixes it, then the culprit is a faulty display.
    7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the moniter but in the computer
    May 18, 2010 | Epson POS TMT88IV Thermal Receipt Printer
    Plastic ruhlatec strip broken
    Hi thereThis is only some thing you can try it may work.
    Solution 1:
    1. Press and hold "left arrow" key
    2. Press the "setup" key and release both keys
    3. Press and release the "OK" button
    4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
    5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
    6. Press and release the “OK” button.
    7. Display should say “Hardware failure status: Clear. Press OK to clear”.
    8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
    9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
    13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    15. If the error is still there, or reoccurs the printer is already defective.
    Solution 2:
    1. Press the On button to turn the printer off.
    2. Unplug the power cord from the back of the printer.
    3. Remove all the ink cartridges.
    4. Wait two minutes.
    5. Plug the power cord into the back of the printer.
    6. Press the On button to turn the printer on.
    7. Install the ink cartridges when prompted.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Mar 11, 2010 | Canon PIXMA MX310 All-In-One Printer
    When I bought the dryer 18 months ago it came with a 3 wire plug and the green ground was attached seperately (not part of the plug). We just moved and the house has a 4 plug setup. I bought a 4 wire plug...
    Good day,
    You wired it correctly. The original setup you had, used a 3 prong, and the white wire could serve as a ground, since all green wires and white wires connect to the same place on the circuit breaker panel.
    Adding an additional green wire from the cabinet to a grounding location, such as a bare cold water pipe is just added safety.
    There might be something wrong inside the dryer, but to be safe, you should have the outlet checked, to make sure the white(common wire) didn't lift off ground potential, and you have a true 230 volts from red to black, and 115 from both white to red, and white to black at the outlet.
    Dec 23, 2009 | Washing Machines
    I can hear the sound, but cannot see the picture
    if its plug into a power strip unplug and wait 2 mins then plug into the wall outlet it self .power is some how weaker in a power strip.
    Jan 17, 2009 | Sony KP-51HW40 51" Rear Projection...
    Laptop is not responding
    1) Try holding down the power button for 5 secs. Let go and try to turn it on again. This is a signal that bypasses the OS and tells the motheboard to power down. This helps if the computer is actually still running but with no display.
    2) If that does not work, unplug the computer, remove the battery and leave it at for 1 min. Replace the battery, plug it in and try to turn it on again. Corrupt data in RAM can cause problems like yours, this clears out the RAM so you start fresh.
    If the above did not help it might be your motherboard. A bad motherboard does not usually damage your data. You can remove the hard drive and put it in a portable hard drive enclosure (about $30), the enclose plugs into a USB slot in a working computer and shows up as another hard drive.
    Check to make sure your power is ok, I ran into a situation where the power bar was accidentally turned off and then the battery ran down.
    Jan 08, 2009 | IBM ThinkPad 600X Notebook
    WS 55315 Tv won't turn on-
    Thanks for your help can you send photos so I can see what to look for
    Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
    Problem with scanning both from the auto feeder and from scanner glass
    this is what HP has to say
    This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
    • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
    • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
    • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
    • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
    • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
    Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
    1. Raise the cover of the product.
    1. Check inside for loose or broken parts.
    2. If there are broken parts, the product needs to be serviced.
    3. Step two: Make sure that accessories are installed correctly
    1. Press the power button (c00636182.gif ) to turn off the product.
    2. Remove the power cord from the back of the product and unplug the power cord from the power source.
    3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
    4. Plug the power cord into the back of the product and plug the power cord back into the power source.
    5. Press the power button (c00636182.gif ) to turn on the product.
    6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
    7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
    8. If the noise persists, proceed to the next step.
    Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
    2. Disconnect the USB cable from the product.
    3. Unplug the power cord from the wall outlet and from the back of the product.
    4. Wait a couple of minutes to allow static to be discharged.
    5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
    6. Connect the product to a different USB port.
    7. Turn on the computer.
    8. Press the power button (c00636182.gif ) to turn on the product.
    9. If the noise persists, service the product.
    Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
    2. Disconnect the power cord from the back of the product.
    3. Remove the rear access door.
    4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Aug 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    True GDM-41 Refrigerator Logo
    148 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
