Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
HELP Green spots
We have a Panasonic PT-61LCX65 61 inch and have a couple of green spots that have appeared on the screen. We cleaned the bulb housing that was suggested in another post but we still have our spots. A local TV repair place said something about an optical unit and that it would cost arounf $1100.00- WOW !! anyone have some ideas on this.. What's an optical unit and how hard would it be to replace.
  • Robert Poling Jun 03, 2008
    green, yellow and red spots and those change position, color and number. also green lines that folow contour of light colored objects like faces for instance.
    Problem Solver:
  • 10 Answers
"eprom upgrade" by a Panasonic tech will solve your problem...
Posted on Feb 01, 2008
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Green tint to bright spots on screen
Try to observe the problem when there is a white screen or predominantly white screen. If the screen is green or yellow where it should be white, its most likely a problem with one or more of the small LCD panels in the TV's light engine.
Its an expensive problem to fix. The light engine most likely will have to be replaced. Check with Panasonic customer relations for possible assistance.
Jan 30, 2009 | Panasonic PT-44LCX65 Television
Green spot
Easy fix. I had the same green spot problem with PT-52LCX65 and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
May 23, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
458 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
