posted by Johnny Lotus on Dec 27, 2007
The oven door is not closing all the way, and the gap at the top is about 1/2" wider tha the bottom. John
Comment by Johnny Lotus, posted on Jan 01, 2008
I think it is hinge related, but there is no way to adjust the hinges that I can see?? JL
Comment by Johnny Lotus, posted on Jan 02, 2008
Is there any referance # for that service bulletin? Is it a recall? I've heard from other resources that Jenn Air has had a history of problems with this door hinge? JL
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 12, 2008
We've had the hinges replaced. Didn't work. Still won't close tightly enough for the light to go out or the fan to operate properly
Best Solution
posted on Dec 29, 2007
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Comment by tech17, posted on Jan 01, 2008
th
Order and install kit # 12002468
there is a service bulliten on that JJW9530DDS
Comment by tech17, posted on Jan 02, 2008
tdc-0017b-b but dont quote me anyway jenn air was made by maytag who was recently bought by whirlpool no recall only recall promblems that are dangerous
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jenn-Air JJW9530C Expressions
Email this problem
Email this problem
Can you Help with these Ovens problems?
Jenn-Air JJW9530C Expressions Collection...
Cooling Fan Won't shut off
Model JMW9530 Wall Oven/... Answer This...
Repair Service
Find Oven Repairman Near You:
Find Parts
