Question about Sanyo DP42746 42 in. Plasma Television
CLICKS OFF AFTER 3 SECONDS
I TURN ON MY TV, AND THEPICTURE COMES ON, THEN CLICKS OFF.AFTER A WHILE JUST A BLINKING LIGHT SI ON THE LOWER RIGHT HAND SIDE,THEN I TAKE THE PLUG OUT OF THE WALL, AND IT'S STARTS ALL OVER AGAIN.PLEASE GET ME SOME ASSISTANCE!
  • TBLADE Dec 29, 2007
    YOU DID'NT EVEN FIX MY PROBLEM.I WOULD LIKE MY $9.88 BACK.I'VE ALERTED PAYPAL ABOUT YOUR COMPANY
    YOU HAVE'NT EVEN FIXED MY PROBLEM.I WOULD LIKETO GET MY$9.99 BACK.IV'E ALREADY ALERTED PAYPAL ABOUT YOUR COMPANY!!!!!!!!!!!!!!!!!!!
    Genius:
  • Sanyo Master
  • 1,689 Answers
Some of the components most likely in the power supply or one of the hard working circuit boards have become thermo sensitive. An experienced service tech can troubleshoot for this and replace the necessary components. Most of the cost will be for the labour more than the parts if they are only common generic type parts.
When there is this type of failure, most of the time in these power supplies and any of the boards that are working under high power factors, the electrolytic capacitors become thermo sensitive with time and age.
There are times with these sets that a complete board will have to be changed to fix the fault. Normaly, these sets are serviced by complete board replacement.
Take care that servicing these TV sets can be fairly expensive, especialy when replacing circuit boards.
Jerry G.
Posted on Apr 12, 2008
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Oct 03, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
I replaced the lamo 6 months ago, but thepicture just went off. The green light flashes then the red light fla
If you turn the set on and the green light blinks then the red light blinks and no other sound comes from the back of the set and you cannot hear any fan turning, you probably have a bad Temperature Fuse. It would be locate either under the lamp assy or on the side of the lamp housing. It would be necessary to remove the Optical Block to get access to it.
I hope this helps,
Skyassoc
Feb 07, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV does not turn on. There is a yellow blinking LED light on the right lower corner of the TV
Disconnect your TV. for few minutes (10) then plug it back on, turn it on using your remote control, wait few seconds, until the light bulb gets its normal intensity, if you can not see anything, but there was a clicking noise,then you bulb it's burn out
Dec 23, 2009 | Toshiba REGZA 47HL167 TV
In my WS 65809 projector tv, when I turn on the power, the green light clicks on for a couple of seconds, then clicks right back off.
DO THIS AND LET ME KNOW WHAT YOU FIND:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Sanyo DP42746 42 in. Plasma Television Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
